RATS in engine bay
Old Mar 16, 2008 | 08:56 PM
sambo32's Avatar
sambo32
Default RATS in engine bay
I do not have a garage and my 01 Vette is parked in the back of my house and covered, when I open the hood I see rat crap around the wiring on the frame rail. I cleaned the entire engine bay, and the next day there is more crap in the same spot. I am scared that these thing will eat my wiring harness, any help would be appreciated.
Old Mar 16, 2008 | 08:58 PM
kingsey's Avatar
kingsey
Build a fence around it. Open the hood on a sunny day and put 20 cats in the fenced in area
Safedog's Avatar
Safedog
How about traps placed under the car for a starter???
Old Mar 16, 2008 | 09:11 PM
SilverScorp's Avatar
SilverScorp
If you think a fence will hold in even one of those cats. your sadly mistaken
Old Mar 16, 2008 | 09:13 PM
Z06ster's Avatar
Z06ster
Are you driving the car everyday or once a week? The longer it sits, the greater the invitation. In a similar vein, you might want to check your HVAC blower and ducting. Mice love to make homes there. Here's what I found in my blower,
Old Mar 16, 2008 | 09:18 PM
C5naples's Avatar
C5naples
You might try some glue boards in your engine bat to catch them. You do want to get them soon because they will munch on your wiring
Old Mar 16, 2008 | 09:19 PM
SLPRC5's Avatar
SLPRC5
You need to place moth ***** under your hood and on the ground...
Old Mar 16, 2008 | 09:20 PM
dobewillie's Avatar
dobewillie
try a few boxes of dcon and get rid of them do a search in the c4 section there were a few posts about some kind of soap bar that repels them good luck
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Get some GLUE traps and set then around the Vette with Peanut Butter in te center!
Tha RAT will go for the Peanut Butter and get glued to the trap and it will remain alive so you can do what you want with it!
I do not want to get into animal rights so do what you think is best with it once it is stuck!
Make sure you check your wiring too!
Thanks,Matt
Old Mar 16, 2008 | 09:25 PM
3whit's Avatar
3whit
Default Rats in engine Bay
Here in Vermont rumor has it that altoid mints placed around the affected area will repel the little buggers. I know sounds weird but the Vets Brother told me he uses it on his collector car and it works ,You can even put them inside and just leave them in the open tin container... Since wire harnesses aren't wrapped with linen anymore mice aren't to interested in chewing . More just making a mess . Hope this helps cant really loose $ 1.59 for a tin ,worth a shot ..
Old Mar 16, 2008 | 09:31 PM
Timbrr's Avatar
Timbrr
Default Rats
Irish Spring and moth ***** in the engine bay, interior and trunk. It takes some time to air everything out in the spring but it beats what you going through now.
Old Mar 16, 2008 | 09:34 PM
paint it black vette's Avatar
a lot of rats in vermont with bad breath.send them to canada. peanut butter and a trap always caught them for me. and use the other stuff to curious to know if altoids work?
Old Mar 16, 2008 | 10:05 PM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
Old Mar 16, 2008 | 10:39 PM
I've heard about using Irish Spring also. Reportedly works so you might want to give it a try.
Old Mar 16, 2008 | 10:57 PM
Mooneypilot's Avatar
Mooneypilot
We have huge rat problems around here and the vector control guys recommend making sure that you kill any snails around the place and keep the dog poop cleaned up. Sounds like B.S. but it does seem to help. Also you could try to avoid parking near hedges or trees as the varmints prowl in there for the snails and stuff. We had to replace a harness in the '02 vert after rat fink chewed the heck out of it.
Old Mar 16, 2008 | 10:58 PM
MKeller's Avatar
MKeller
You need a deer rifle
Old Mar 16, 2008 | 11:45 PM
Rickman's Avatar
Rickman
Ah, Laddie,
Cool, a Rat Motor in an 01.
I would be doin' the Irish Spring right away tomorrow on St. Patty's Day! They will repel them vs. you having to remove them once they are caught/trapped w peanut butter.
The last thing you want is a messed up wiring harness.
Rickman
To RATS in engine bay
Old Mar 17, 2008 | 01:32 AM
sambo32's Avatar
sambo32
Before going to work tonight, I put a old fashion large mouse trap the one with the spring under my vette. I just got home and looked under the car, and what do I see, a LARGE rat cought in the trap, already dead. The size of this rat is about the size of a brick. Hopefully this is the rat that was camping out in my engine compartment.
Old Mar 17, 2008 | 01:37 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Set-out a couple more just in case
Old Mar 17, 2008 | 01:51 AM
DeeGee's Avatar
DeeGee
Looks like you caught that one but he has friends. They're attracted by the warmth of the engine bay at this time of the year. We used to get them in the garage when the farmer cleared out the barn for the sheep. They'd migrate across the road and set up shop. Trouble is they do massive amounts of damage when they start nesting as well as the risk of disease.
I'd drop a tray of rat poison in a small dish. They then take themselves off to look for water and dont make a mess when thy move on. Don't forget to take it out before you drive though.
