Service Column lock
1: Do I need to get the locking plate removed?
2: Do I need to get all the codes cleared before installing the CLB?
3: Should I let the dealer install the CLB?
4: Once the locking plates is removed and the K harness is still there, and if they reflash the PCM. Will this cure the column lock code?
They need to remove the codes
after repeated issues i found out that if i leave my vette off a tender for the winter or for long periods of storage time, you get the message due to low battery charge. I have recreated the issue so i know they aren't just pulling my chain.
I thought they were full of it since the battery had enough to start the car.
No
Its a good idea right before you start it up after install.
No. Go to www.ls1howto.com scroll down about half way on the right side click to get illustrated instructions.
In the instructions you will remove a fuse.
Remove the K harness before you install the CLB.
Yes.
Keep your battery in good shape. Low battery voltage on the PCM bus causes the issue.
Installing the CLB only took about 30 minutes for me. However - putting the lower dash back together took much longer.
I had all 3 recalls done & it still locked...My dealership charged me an arm & a leg to fix it, but I just ordered a CLB so hopefully it won't happen again....
a. I have had the battery on a voltage tender during the winter. I guess I should charge up my battery and see what happens.
b. If the battery fixes the problem,should I install that CLB fix too ??
It is nice to know that others have experienced this and know what to do. I hate to take the car to the dealer!
DH
You need a good battery. Low voltage on the PCM bus caused the problem.
Refer to the instructions located at www.ls1howto.com scroll down right side #5 and click the link to do the CLB.
Order the CLB and install it. Follow the instructions above.
You'll pull a fuse for a period of time to clear the condition.
If the column is locked you must get it unlocked to proceed with the installation. There are recommendations in these threads on how to get it unlocked, shake wheel back and forth, while turn the key to on, remove the appropriate fuses, and clear the DTC codes.
Hope you get it working again soon.
