Wheel Spacer ??
Old Mar 20, 2008 | 09:59 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Wheel Spacer ??
I just put some wheel spacers on my back wheels....I measured the spacer with a my dial caliper and they measured 3/10ths of an inch. What is the rule of thumb on how much stud should stick out.
Obviously Im not going racing with these but I just like how it makes it look daily driving.
Chris
Old Mar 20, 2008 | 10:05 PM
damilleniumboy's Avatar
damilleniumboy
Old Mar 20, 2008 | 10:38 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
the NHRA used to specify 2 threads must show. that was with open lug nuts
Old Mar 20, 2008 | 10:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Chris
with the awesome front and rear fascias that your car is sporting, i think your car would look wicked with a wider stance.
the only thing that would top it off would be some flared quarters in the back.
Old Mar 20, 2008 | 10:51 PM
Marc77's Avatar
Marc77
Rule of thumb (so, I'm told) the lugnut should get a least 4-5 full threads minimum to be safe. FYI, I used 1/4" spacers on mine and the lugs grabbed about 6 threads. From research on the forum, I think if you went with a spacer thicker than 5/16", you wouldn't grab enough threads and it's not safe.
Old Mar 20, 2008 | 11:05 PM
Corvette-Chris
St. Jude Donor '08
Thanks man, I agree that it would look sick with the flared quarters. Just like yours
I think mine are just a tab smaller than 5/16....Ill probably just keep eye on the lugs
Old Mar 21, 2008 | 12:49 AM
jdmvette's Avatar
jdmvette
Night Owl for life
that's good info, marc77.
i use 1/2" spacers but i had to change to longer studs.
To Wheel Spacer ??
