Vin check please
VIN : 1G1YY22G9Y5130903
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2000 CORVETTE COUPE Warranty Start Date : 06/06/2000
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : FRANK PARRA AUTOPLEX, INC.
1000 E AIRPORT FWY
IRVING , TX 75062-4813
(972) 721-4300
Selling Source : 13 - CHEVROLET
Site Code :
Business Associate Code :
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/06/2000 4 miles 06/06/2003 36004 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/06/2000 4 miles 06/06/2006 100004 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/06/2000 4 miles 06/06/2008 80004 miles
36/36000 FEDERAL EMISSION 06/06/2000 4 miles 06/06/2003 36004 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/12/2005 293920 # V1153 - 04006 - INSTALL HARNESS KIT - AUTOMATICS ONLY 36877 miles
04/22/2003 492162 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 21015 miles
04/22/2003 492162 # Z7901 - 1-DAY COURTESY TRANSPORTATION 21015 miles
03/17/2003 487084 # N0110 - BATTERY - ONE - REPLACE 20291 miles
03/17/2003 487084 # T2020 - TOWING 20291 miles
03/14/2003 486734 # N6602 - WIRING AND/OR CONNECTOR - CHARGING/STARTING/BATTERY - REPA 20239 miles
03/14/2003 486734 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 20239 miles
03/14/2003 486734 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 20239 miles
03/14/2003 486734 # T2020 - TOWING 20239 miles
02/21/2003 483816 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 19950 miles
10/18/2002 462881 # N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE 17565 miles
06/26/2002 442963 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 15681 miles
06/18/2002 441719 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 15492 miles
06/18/2002 441719 # C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 15492 miles
01/30/2001 361245 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 4974 miles
05/30/2000 A30903 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
VIN 1G1YY22G9Y5130903
VEHICLE BUILD
Gross Vehicle Weight Rating : 1675 kg (3693 lb) Order Number : CJZCG3
Build Date : 05/30/2000 Build Plant : 1Y5Y - BOWLING GREEN
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS AQ9 - SEAT FRT BUCKET, PASS, DRIVER
BGR B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED
CF7 - REMOVABLE SUN ROOF CJ2
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
D42 - REAR COMPARTMENT CARGO COVER FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS G90
G92 - PERFORMANCE AXLE RATIO IL3
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63
LS1 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM
NK4 - LEATHER WRAPPED STEERING WHEEL N37
QG1 T82 - TWILIGHT SENTINEL HEADLAMPS
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 UV7
UZ6 U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG YGH
1SA - OPTION PACKAGE 01 19I - INT EBONY INTERIOR TRIM
193 28U - NAVY BLUE METALLIC
