Climate control problem!
Old Mar 21, 2008 | 05:30 AM
bradenW's Avatar
bradenW
Default Climate control problem!
My climate control display either doesn't light up at all or when it does, it is very very dim. Anyone else had this and what is the fix for this? (new c5 owner)
Old Mar 21, 2008 | 05:36 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Use the search feature. It's a common problem and you'll find more advice than I can give.
Old Mar 21, 2008 | 05:50 AM
jdmvette's Avatar
jdmvette
Night Owl for life
this is what i used.
linky
you can DIY for much cheaper, but i didn't want to monkey around with it.
there's also more sellers like this, but i liked the fact that i got the new unit first, instead of not having it for a week or so.
Old Mar 21, 2008 | 06:09 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
http://forums.corvetteforum.com/show....php?t=1583758
Old Mar 21, 2008 | 08:59 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Originally Posted by still-asleep
can't go wrong with these directions!
and best of all, it's FREE!
Old Mar 21, 2008 | 12:03 PM
dankhts's Avatar
dankhts
I had the same problem with my '02 vert, it seems to be very common, mine was still under warranty though, and the dealer changed it for me....
Old Mar 21, 2008 | 12:10 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
St. Jude Donor '05-'06
fixed mine in about an hour from start to finish using the link that still-asleep provided
Old Mar 21, 2008 | 01:03 PM
damilleniumboy's Avatar
damilleniumboy
My car is like that, and I have been watiting to do it because I'm being lazy .
Old Mar 21, 2008 | 01:59 PM
env00's Avatar
env00
....with all regarding the dim light fix.
FYI, about 7 months after I made this mod, I couldn't turn off or change the temperature...ended up replacing the unit with a new one from Gene (vendor on this forum).
Old Mar 21, 2008 | 02:04 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I fixed my own as stated above, But if you don't want to do it your self go here LED FIX
Old Mar 21, 2008 | 02:16 PM
LLVETTE's Avatar
LLVETTE
Took my time and did it in about an hour. Easy to do if you've ever touched a soldering iron. If not take 10 minutes and practice on something first and then go for it.
Old Mar 22, 2008 | 01:03 AM
bradenW's Avatar
bradenW
Thanks guys!
To Climate control problem!
