Compact Jack - No Pucks Required
Old Mar 21, 2008 | 06:22 PM
4 KRUSIN's Avatar
4 KRUSIN
Default Compact Jack - No Pucks Required
I've been watching for a nice compact jack for some time now. My floor jack is too big to fit under my car and requires pucks even if I could use it. I also want one that is small enough to carry in my emergency kit should the need arise since I am not using run-flats anymore.
I found this little gem at the local junkyard for $10. At Its lowest, it is only 2.75 inches. Its out of an early 90's mid size Olds, but any mid size GM from that era should be the same. I tried it this morning, and it does not require pucks because it easily clears all of the bodywork. The built in wrench on the handle even fits my lug nuts.
If any of you are looking for a jack, this is a good one.
Dave
Old Mar 21, 2008 | 08:16 PM
RonJ's Avatar
RonJ
I think I remember that jack, it has a groove in it to fit over the flange between the floorpan and rocker. That's what kept the jack from slipping out.
I'd be concerned about that flat lifting area slipping on the smooth metal lifting area on the car though. I'd still be tempted to use a puck or something so the jack wasn't as liable to slipping/kicking out.
My 2 cents!
RonJ ...
Old Mar 21, 2008 | 08:20 PM
moserbe's Avatar
moserbe
Old Mar 21, 2008 | 08:23 PM
Carz4Toyz's Avatar
Carz4Toyz
That looks amazingly similar to my Dodge Viper Jack!
Old Mar 21, 2008 | 08:56 PM
dobewillie's Avatar
dobewillie
good post Dave thanks
Old Mar 21, 2008 | 09:19 PM
Wisdom's Avatar
Wisdom
I recently needed help at work due to an unexpected flat tire. My daughter and son-in-law responded with their '07 Ford Taurus scissor jack and lug nut wrench. Very impressive kit. Low profile, 19mm, nice secure carrying case. I'll be buying one for my car.
- Wisdom
Old Mar 21, 2008 | 09:22 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
NO...That looks amazingly similar to a c4 jack
Old Mar 21, 2008 | 09:37 PM
STL94LT1's Avatar
STL94LT1
Just went out and looked at my C4's jack. They are one in the same, and it will fit under my lowered C5.
Old Mar 21, 2008 | 09:43 PM
0JPM@AutoBuffs
Former Vendor
I know it as I use my dads C-4 jack from time to time to do work on my C5!
Old Mar 21, 2008 | 11:03 PM
Oldvetter's Avatar
Oldvetter
If you expect to use this to change a non-runflat tire, try letting the air out of a tire and then try to get jack under the car. You will lose 2 inches, clearance is about 2 inches. Good luck.
Old Mar 21, 2008 | 11:17 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I got a cool little aluminum jack from Costco. it's pad sits about 3" above the ground it sits on so it's good for even some lowered cars.
Old Mar 22, 2008 | 12:34 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
That little jack in the OP's post looks very similar to an F-Body jack. I've used one of those every time I've put a C5 in the air because of how easily it gets under there.
Old Mar 22, 2008 | 05:38 PM
4 KRUSIN's Avatar
4 KRUSIN
Thanks for the input.
I just double checked the clearance and all is good. My non-lowered Vette has 5.5" of clearance where the jacking points are and with a flat I will have about 3". That gives me a liitle to spare. Guess I won't lower the Vette in the future.
I still recommend this jack.
Dave
To Compact Jack - No Pucks Required
