help. drivers side window stuck closed
Old Mar 23, 2008 | 02:11 PM
robsciam's Avatar
robsciam
Default help. drivers side window stuck closed
Happy easter all. Went out today and started my vette {2001 z06} and rolled down window. Shortly after i rolled it back up and now it wont move up or down. Passanger side is fine so i assume its not a fuse. Any input would be helpfull. ty
Old Mar 23, 2008 | 02:37 PM
Bill Vett's Avatar
Bill Vett
Does the passenger side work if you use the drivers controls or only when you use the passenger control? Did you check to see if there any codes?
Here are a list of drivers door codes.
A0-LDCM - Left Door Control Module
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2222 LT Mirror Select Switch Fault
B2224 RT Mirror Select Switch Fault
B2226 Mirror Right Switch Fault
B2228 Mirror Left Switch Fault
B2232 Mirror Up Switch Fault
B2234 Mirror Down Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2242 Memory 1 Switch Fault
B2244 Memory 2 Switch Fault
B2252 Key Cylinder Switch Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
B2272 Left Mirror Motor Fault
B2274 Window Motor Fault
B2276 Door Lock Motor/Mirror Heater Fit
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2286 +5V Reference Fault
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Old Mar 23, 2008 | 02:47 PM
Rocky57's Avatar
Rocky57
Old Mar 23, 2008 | 02:52 PM
robsciam's Avatar
robsciam
passanger side is fine with drivers controls. Didnt check for codes yet, could you please remind me how to. ty
Old Mar 23, 2008 | 03:03 PM
robsciam's Avatar
robsciam
just checked codes, and all were old {history} but i will post them anyway.
b2282h
b2284h
u1064h
u1016h
b2283h
u1064h
Old Mar 23, 2008 | 03:16 PM
Bill Vett's Avatar
Bill Vett
Looked at the codes... Try this .
open the drivers door, look for the accordion tube that wires from the door to the pillar are. Pull both ends out to from door and pillar. Once removed pull the wire bundle from the door pillar. There should be a plug. Disconnect the plug. check for a dirty connector, re connect and try the door controls, push the bundle back in the pillar replace the accordion. let me know if it helped. Bill
PS make sure that the battery if fully charged, you didn't mention how long since you last started the car of if it was on a battery tender.
Old Mar 23, 2008 | 03:23 PM
robsciam's Avatar
robsciam
sounds good bill, i will try that when i get back from easter dinner.The car has only been sittting a day and the battery is only 3 months old.Enjoy your easter and i will let you know how i made out . ty
Old Mar 23, 2008 | 03:35 PM
Bill Vett's Avatar
Bill Vett
Happy Easter Ty, Good luck. Bill
Old Mar 23, 2008 | 07:19 PM
robsciam's Avatar
robsciam
tried removing the tube that contains the wires but didnt feel comfortable unpluging the wires because they seem to go into the door pretty far. They looked brand new as the car only has 14k miles on it. Would the car throw a code if the regulator went bad? Also if the wires were loose or dirty wouldnt that effect all the controls on the door, because all the others work ?
Old Mar 23, 2008 | 10:10 PM
Bill Vett's Avatar
Bill Vett
There's plenty of wire to pull the plug out of the pillar, In the photo you'll see a wire with a clear tube around it, that's a drain so water doesn't flood the speaker in the door. If water got into the plug one of the wires could be the problem. I'd at least unplug and plug in again to see if that worked. Inspect both sides of the plug for any signs of a loose wire.
Old Mar 24, 2008 | 02:51 PM
robsciam's Avatar
robsciam
thanks bill,i will try that. I thought you meant pull it out from the actuall door
Old Mar 24, 2008 | 04:50 PM
robsciam's Avatar
robsciam
i just pulled it apart and everything looks good, almost brand new. Maybe tomorrow i will try and remove the door panel (yikes).
To help. drivers side window stuck closed
