car started to make a weird noise then the check engine light came on so i went to this site to check the codes, it says the H means history of the an old code thats been fixed but what does the C mean. http://www.stengel.net/diccodes.htm
ex. here are some codes that came up
thanks, it prob. is bad fuel went to a untrustworthy gas station the other day and filled up with 93 but that prob is the problem, so i should just get a bottle of techron.
Also threw this code, but do not not what it is
C2120 C- site says it is a TPM System Malfunction (No Sensors Received)
It means the computer is not seeing the output from the tire pressure monitors. Are you getting readings for tire pressure on the DIC?
You have a receiver in the car that picks up an RF signal from the sensors. The RFA is shared with the key fobs. Do your key fobs work OK? If so its not the receiver.
