Right Side Window Kaput
Old Mar 26, 2008 | 11:25 AM
BobH's Avatar
BobH
Default Right Side Window Kaput
All of a sudden my right side window won't work. Mine's a 2004 and almost 4 years old. Any electrical fuses/circuit breakers to check? I have the extended warranty so if I can't fix via a simple fuse it's going to the dealers.
Thanks in advance.
Old Mar 26, 2008 | 11:44 AM
TEXHAWK0's Avatar
TEXHAWK0
If you can hear the relay click when you push the button, but the window does not even try to move, you will probably need to have the window regulator assembly replaced.
They can just quit without warning.
I have already replaced both regulators on my 04.
Sometimes you can get them to work awhile by tapping on the motor, but once they mess up, you can save aggrivation by just having it replaced.
I preferred to do it myself, but GM did pay for the part.
Old Mar 26, 2008 | 12:18 PM
LT1SPUD's Avatar
LT1SPUD
CHECK THIS THREAD OUT... worked for me and no problem since..
http://forums.corvetteforum.com/show...hlight=LT1SPUD
Old Mar 26, 2008 | 12:20 PM
robsciam's Avatar
robsciam
mine just took a crap 2 but it doesnt make noise when i push the button.
Old Mar 26, 2008 | 01:01 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
mine died not long ago. you could hear the click when the button was pushed. had to get the regulator/motor replaced.
Old Mar 26, 2008 | 01:20 PM
Tom/99's Avatar
Tom/99
Both of the window motors have gone bad on my 04 coupe. I guess it's an expected repair on the C5's. I had to have one replaced on my 99 also.
Old Mar 26, 2008 | 01:23 PM
2K4Vert's Avatar
2K4Vert
My passenger side window stopped working on my 04 vert a couple of weeks ago. I have been waiting for a good time to take it to the dealer to fix (under warranty). Washed my car this past weekend, and poof!! it started working. Didn't do anything I haven't done for the past couple of weeks, except wash it. I expect this to be temporary, but it has worked for the past 4 days.
Old Mar 26, 2008 | 02:23 PM
BobH's Avatar
BobH
Thanks guys, a sharp rap on the lower door while pressing the button worked. The window A-OK for now. I think gold plated contacts would solve the resistance issue.
Old Mar 26, 2008 | 05:36 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Had that happen on my 03 when it was two years old had the window regulator replaced at chevy
To Right Side Window Kaput
