Code Breaker
Old Mar 27, 2008 | 03:48 PM
jmeneijr's Avatar
jmeneijr
Cruising
Default Code Breaker
I have read the following codes from my Driver Information Center in my 2003 Corvette.
A0 LDCM U1064 H
A1 RDCM U1064 H
What I do know is LDCM stands for Left Door Control Module & Right Door Control Module (RDCM).
What is the code after these designations?
Any help would be greatly appreciated.
Old Mar 27, 2008 | 03:59 PM
87SAM's Avatar
87SAM
From the manual:
DTCs U1016, U1064 and U1096 may be present when scrolling through the onboard diagnostics via the instrument cluster Driver Information Center (DIC).
Recommendation/Instructions:
This is a normal software function as long as the DTCs have a history status upon ignition cycling. No repair attempts should be made
Old Mar 27, 2008 | 08:57 PM
jmeneijr's Avatar
jmeneijr
Cruising
Hi 87Sam,
Thank you for your answer. Are you refering to the Owners Manual or the Shop manual. I have both & will look again tonight.
I am not real impressed with the GM Shop Manual. I think Acura does a much better explanation.
Thanks again,
Jim
To Code Breaker
