active handling/run flats
Old Mar 27, 2008 | 04:12 PM
MrVette04's Avatar
MrVette04
Cruising
Default active handling/run flats
Hi all. I am a new member to this great forum. I just purchased my first vette (2004 spiral gray automatic coupe) and am now officially addicted These cars rock!
Two questions for the group:
(1) what are the purposes of the active handling and competitive driving modes? In what situations would you use one over the other?
(2) do regular tires offer a smoother vette ride than the run good year run flat tires (assuming you have a mobile air device for flat tires)?
Old Mar 27, 2008 | 04:19 PM
steve8's Avatar
steve8
When you enter comp mode, that disables the traction control but keeps the active handling in play. Disable both, and you are on your own.
Prepare to be bombarded about the runflats.
Yes, non runflats will ride better/quieter, but there is a trade off with everything.
You have been warned, be prepared.
Old Mar 27, 2008 | 04:20 PM
steve8's Avatar
steve8
BTW, welcome to the forum.
Old Mar 27, 2008 | 04:24 PM
MrVette04's Avatar
MrVette04
Cruising
Thanks for the warning and the welcome Steve8!
Old Mar 27, 2008 | 04:31 PM
Great White North's Avatar
Great White North
Welcome to the habit!!
Old Mar 27, 2008 | 06:28 PM
Bill Dearborn's Avatar
Bill Dearborn
AH uses brake control to point the car in the direction the driver wants to go. It detects if the car isn't yawing as fast or faster as the driver wants and applies one brake to correct the yaw rate. It works in conjunction with the TC when in full mode. In comp mode the TC is turned off and the handling parameters for AH are opened up a little (especially on 01 and newer models) to allow the driver to slide the car around a little more.
Non run flat tires ride smoother than the GY EMTs but are not that much different in ride quality than the Firestone run flats or a couple of other brand run flats.
Bill
Old Mar 27, 2008 | 06:31 PM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
congrats on your purchase Feel free to fill out your profile
Old Apr 21, 2008 | 10:06 PM
RogerArrambide's Avatar
RogerArrambide
How can I know if my Vette has this feature? (Active Handling)
How I activate the competitive driving mode?, I left pushed the button for more than 10 sec and nothing happens..
Old Apr 21, 2008 | 10:19 PM
dobewillie's Avatar
dobewillie
congrats and welcome
Old Apr 21, 2008 | 11:10 PM
Welcome to the forum. Yes, non-runflat tires generally will give you a better ride, less noise and better handling than runflat tires.
Old Apr 22, 2008 | 12:41 AM
BlueC5Kitten's Avatar
BlueC5Kitten
From: If you're not part of the solution, you're part of the precipitate. Texas
CI 4-5-6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
But if you look around/ask around, there are lower road-noise alternatives in RFTs. I have had the Firestone Firehawks and am running the Kumho Ecstas now...both are better than OEM, imho.
Welcome, btw!
Old Apr 22, 2008 | 01:38 AM
DeeGee's Avatar
DeeGee
Welcome to the Forum
It looks like you already got some good descriptions of what AH does.
I leave AH in all the time because I don't track the Vert but you'll get varying views. Some ditch it on start but my view is that it's there for a reason and that's not too smart. It saved my behind on more than one occasion when the road conditions didn't go my way. Many of the guys that track their car drop it and also use Competetive mode. I can well understand that when they're pushing the car to the limit under controlled conditions on a track they've studied.
On the runflats; the OEMs are noisy and hard to get the 200 miles running without air which the spec demands. I found them prone to wheel hop and tramlining.
I switched to Michelins AS ZPs which are way quieter and handle better but ar only rated for 50 miles flat. The softer sidewalls make the difference.
You can go for non RFs and its an improvement as well. I tried the Michelin PS2s but it didn't give me the quantum improvement that I'd have needed to lose the protection of the run flat. I guess if you live in a city or have AAA on call you could live with that
JMHO
Old Apr 22, 2008 | 01:48 AM
DeeGee's Avatar
DeeGee
Active Handling was introduced in 1998 as an option but became standard in 2001
The RPO code if it was fitted as an option is JL4.
Old Apr 26, 2008 | 09:49 PM
RogerArrambide
What doest code JL4 mean?
And how can I active the competitive driving mode?
Old Apr 28, 2008 | 10:44 AM
Polar Jet's Avatar
Polar Jet
If your vehicle has AH, just press and hold the button on the center console down for 5 seconds. Your DIC will indicate that it is active.
Old Apr 28, 2008 | 06:13 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
You hold the AH button down for 5 seconds, you hear a ding and the DIC will display "competitive driving". If you held the button down for 10 seconds and it didn't switch to this mode then you don't have it.
To active handling/run flats
