[Z06] LCA rubbing on Wheel !
Old Mar 27, 2008 | 06:42 PM
CheckABS's Avatar
CheckABS
Default LCA rubbing on Wheel !
I finally got my 315's in for my 18x12 ccw classics for my c5 z06.
I put the wheels on and when I went to back up the car from my garage, I heard a pretty horrible noise. I got it back in the garage and noticed that my LCA's shaved a circle around the backside of my wheel.
Its not horrible but it made me really upset.
The car is lowered on stock bolts ( or are they aftermarket bolts? ).
I asked my friend and he told me to raise it up on the bolt.
I went to raise it up but I can't tighten the bolt anymore from the bottom while holding the top bolt in place. No more threads.
What is my best fix and I really want to run these wheels.
* friend suggested getting bushings... what will that do ?
Old Mar 27, 2008 | 07:19 PM
TM-Z06's Avatar
TM-Z06
The less expensive route - Get a 1/4" - 1/2" spacer/adapter
The more expensive route - get new inner barrels from CCW to make the wheel 11.5" wide
Old Mar 27, 2008 | 08:13 PM
rhneff's Avatar
rhneff
Methinks there's something strange going on here. I run 18x12 CCW's on the back of my 02 Z, with 335's mounted, no spacers, lowered on aftermarket springs beyond the max capable with stock springs/bolts, and aside from an occasional tire rub on the fender liner with hard cornering I have no interference issues at all.
My suggestion would be to call John (Purner) at CCW talk and him about the problem. He's forgotten more about wheel fitment than the rest of us collectively know and I'll bet he can figure out the real issue in short order.
Old Mar 27, 2008 | 08:34 PM
zulatr's Avatar
zulatr
had to ask, what's an LCA?
Old Mar 27, 2008 | 08:38 PM
Z06JPB's Avatar
Z06JPB
lower control arm
Old Mar 28, 2008 | 12:23 AM
CheckABS's Avatar
CheckABS
I was actually told that its rubbing on the leaf spring... I will post up some pictures if i get a chance 2maro !
Thanks guys
Old Mar 28, 2008 | 02:15 AM
jclarksnakes's Avatar
jclarksnakes
Do you know what the offset is on those CCWs? My guess is that you got some with the offset different than the 18X12s that other people are using. Like was already posted spacers may solve the problem for you.
Jeff
Old Mar 28, 2008 | 08:10 AM
AU N EGL's Avatar
AU N EGL
Your car may be too low. Time to raise it back up to no lower then 1" from stock ride height.
Old Mar 28, 2008 | 08:48 AM
Twil1ght's Avatar
Twil1ght
Thanks guys
It's the leaf spring. It happens when people put wider than stock wheels on the car and lower it beyond the suspension's optimal working range due to the position that places the leaf spring in relation to the wheel. This is where engineers would say "works as designed."
Old Mar 28, 2008 | 08:59 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Glad I was not the only one who did not know what they were talking about.....
Old Mar 28, 2008 | 10:15 AM
bmg's Avatar
bmg
Dump the leaf springs and buy some coilovers. You will have the extra suspension travel that you need to have the car perform as it should and no wheel problems!
Old Mar 28, 2008 | 12:30 PM
Slow Z06's Avatar
Slow Z06
If it is truly hitting the control arm, one remedy is to grind a small amount off the arm where it hits the wheel.
Old Mar 28, 2008 | 01:24 PM
Twil1ght's Avatar
Twil1ght
Hey there's an idea! ...for really slamming your car down and making it not handle well at all you need to go a step further though... remove the springs on the front and the rear, take the shocks out and replace them with some fixed posts so you can set the car exactly where you want it and have no suspension at all!
Old Mar 28, 2008 | 01:30 PM
jmc12's Avatar
jmc12
I'm funny in some ways I guess... I WOULD NOT DO THAT..
Old Mar 28, 2008 | 01:56 PM
Slow Z06's Avatar
Slow Z06
Im not talking about an insane ammount or gouging out the arm, more so like polishing it. Also depends on how bad its hitting. But hey, to each their own. I see some people here put their rear calipers on the front so they can run a 15 in runner there..........
On another platform, there are those of us who take the mirrors off our bikes, use lighter material to shave weight, and drill holes in the side of our fairings for sliders. All in the name of going faster....
Old Mar 28, 2008 | 02:15 PM
Twil1ght's Avatar
Twil1ght
...those are some of my favorite people...the ones who think they know what fast on a bike is and have never stood on the box.
Old Mar 28, 2008 | 02:24 PM
bmg's Avatar
bmg
This may cause the leaf spring to delaminate which is not good!
To LCA rubbing on Wheel !
Old Mar 28, 2008 | 02:28 PM
Slow Z06's Avatar
Slow Z06
Why would the spring de-laminate?? You are working on the arm not the spring.
Old Mar 28, 2008 | 02:30 PM
Slow Z06's Avatar
Slow Z06
When I was managing CycleGear I had a ton of those....Fast guys.....come in. Hell even at the track there are alot of the " im fast" guys there. Shucks, I'm slow by most standards but I have fun doing it.
Old Mar 28, 2008 | 02:32 PM
Slow Z06's Avatar
Slow Z06
Hell I just re-read this whole thread. I missed where he said it was the spring hitting. Disregard grinding of anything. Raise your car back up or get 1/4 spacers.
