Installed Halltech stinger - oil question...
Old Mar 30, 2008 | 09:07 AM
bhoch's Avatar
bhoch
Default Installed Halltech stinger - oil question...
The install was pretty easy. Took me about 1 hour, total... Almost took longer to get the sensor out of the air bridge to install in the halltech airbridge then to do the rest of the install.
After install, started, no codes, no problem. Took it for a short drive, no problems.
So, I realized, after it was installed that I did not have the oil to put on the filter. Question - are we able to ge the oil to use locally (autozone, etc...) or must it be ordered?
Thanks,
Old Mar 30, 2008 | 09:16 AM
Blown 346's Avatar
Blown 346
You can buy/use any K&N filter oil from any parts store. You can either buy the spray bottle or the bottle. I myslef would use the spray bottle, its less messy.
Old Mar 30, 2008 | 09:19 AM
bhoch's Avatar
bhoch
Thanks! I'll head there this morning!
Old Mar 30, 2008 | 11:17 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Hi bhoch,
Be careful, as a lot of these filters come pre-oiled. You don't want to do it again - too much oil will mess with your MAF.
Old Mar 30, 2008 | 02:32 PM
bhoch's Avatar
bhoch
Originally Posted by wamara
Hi bhoch,
Thanks for the info! This one looks/feels dry though!
Old Mar 30, 2008 | 02:41 PM
hotwheels57's Avatar
hotwheels57
Actually, the spray applicator is what gets most owners in trouble with over oiling and contaminating of the MAF.
S&B FILTERS realized that and eliminated the spray applicator and started supplying a small squeeze bottle applicator with the exact measured amount of oil.
HALLTECH, like many after market intake systems, might be using an S&B FILTER as they offer their products in red or blue media and red or blue oil. You probably should contact HALLTECH.
If you prefer to use the spray applicator, oil sparingly onto the clean dry media. K&N cleaning solution and oil will work fine on an S&B FILTER (unless you use red oil on a blue filter media).
Old Mar 30, 2008 | 02:53 PM
bhoch's Avatar
bhoch
hmm.. my filter is blue and white. Can I not use the I bought oil spray for air filter... Can I not use this?
Old Mar 30, 2008 | 03:15 PM
hotwheels57
What part of the filter media is white? From every image I've seen and the HALLTECH website, the filter media is entirely blue (or entirely red if S&B FILTER is the supplier).
If you bought the K&N cleaning and oiling kit, you can use it on an S&B FILTER, but red oil on blue filter media might change the color of the media. They're both cotton gauze filter media.
Maybe the white area is where no oil wicked into?
From looking further into the HALLTECH website, I do believe they use S&B FILTERS in their systems.
http://www.halltechsystems.com/category_s/42.htm (click on filter cleaning and oiling)
Old Mar 30, 2008 | 04:35 PM
bhoch's Avatar
bhoch
Well, Boy is my face red.. (well, blue, actually).. It's blue. It is not blue and white. I went out to take a picture of it and it's blue - entirely. I wonder now, why I thought it was blue and white.
Anyway, it's oiled and good to go till the first cleaning is required!
Thanks for all of the responses!
To Installed Halltech stinger - oil question...
