Corsa POP
Old Mar 31, 2008 | 10:25 AM
DUBI's Avatar
DUBI
Default Corsa POP
Anybody getting a pop-- backfire on the Corsa exhaust ---when you rev the engine?? Sounds like my Vance and Hines before I put in a programmer.---
Old Mar 31, 2008 | 10:31 AM
Blown 346's Avatar
Blown 346
Do you have cats?
Old Mar 31, 2008 | 10:32 AM
RJS91RGTP's Avatar
RJS91RGTP
Default Corso Pop
I would bet that you don't have an X-pipe installed on your car. If you have an X pipe the pop will be removed. With the X-pipe you idle sound will be quieter as well. It all depends on what sound you are looking for and like.
RJ
Old Mar 31, 2008 | 10:47 AM
DUBI's Avatar
DUBI
Default Pop
No X-pipe and Cats are in!!!
Old Mar 31, 2008 | 10:52 AM
mjoy's Avatar
mjoy
I know with mine if I hammer it when it shifts from 1st to 2nd I get a strange sound that could be considered a backfire. Sounds kind of strange but performance is good, and like I said it only does it at WOT. I don't have X pipe and cats are still there.
Old Mar 31, 2008 | 10:55 AM
Slow Z06's Avatar
Slow Z06
I got kooks lt's, xpipe, no cats, and AIR delete. Pops like glass packs on decel
Old Mar 31, 2008 | 11:13 AM
env00's Avatar
env00
I've got Corsa's and know exactly what you mean...add the x-pipe (I also have stock cats)...it'll get rid of most if not all the popping...you'll still have a "gurgle" noise when you down rev though (livable)...good luck...
Old Mar 31, 2008 | 11:20 AM
MagRedConv's Avatar
MagRedConv
I have the same set up.
Old Mar 31, 2008 | 11:21 AM
02MillenniumVette's Avatar
02MillenniumVette
RJ
If you dont have cats then it will still pop with a X-pipe.
Old Mar 31, 2008 | 12:52 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Mine doesn't:o
Old Mar 31, 2008 | 02:09 PM
Slow Z06's Avatar
Slow Z06
Old Mar 31, 2008 | 03:18 PM
Dark Syde's Avatar
Dark Syde
Cruise-In VII Veteran
I have Corsa Indy with no x-pipe... coming into the neighborhood, deceleration and going down-hill... P-P-POW... I love it!! The neighbors know I am home.
Old Mar 31, 2008 | 03:50 PM
DUBI's Avatar
DUBI
Default Pop
I get it just revving in the driveway!!!!
Old Mar 31, 2008 | 03:55 PM
mbroadway's Avatar
mbroadway
Default Yeah...
I get a little of glass pack sound when decelerrating. So, what's not to like about that?
Michael in KC
Old Mar 31, 2008 | 04:01 PM
black98c5's Avatar
black98c5
Nope! I've got Dynatech LT's, X-pipe (catless), and a healthy cam.
Old Mar 31, 2008 | 04:50 PM
mrgil's Avatar
mrgil
Burnout
Default Pops?
I've got Dynatech Supermaxx LT's ceramic coated in and out, Hi flow cats, X-pipe and Corsa touring and NO popping, Sounds awesome at hi rpm, I love 'em.
Installation of the Corsa's was a snap. Used a lift and also installed Z06 sway bars front and rear. about 2 hours.
Tip alignment was easy.
mrgil
Old Mar 31, 2008 | 04:58 PM
My B&B Route 66s did the same thing - installed an X-pipe and the popping was gone.
To Corsa POP
Old Mar 31, 2008 | 05:31 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Corsa,no cats,TPIS headers,X-pipe.I get the popping but,only on decel
Old Mar 31, 2008 | 06:03 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
I call it the angry shotgun.
I have American Racing Headers, Xpipe and hiflo Cats. Corsa Pace GTR.
When you acelerate, and then let off i can a pop and then a grumble.
You can purposely make it happen every time by hitting 50 mph in 3rd gear and then just let off hard on the gas. POP.
Normal. Its pressure equalization.
If you get it with JUST a rear change, not the headers back, you might have a loose baffle.
Old Mar 31, 2008 | 06:14 PM
jrose7004's Avatar
jrose7004
Get a X-Pipe.
