Euro tails?....
Old Apr 1, 2008 | 07:59 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Default Euro tails?....
Anyone with pictures/video of the euro taillights at night? How about with the turn signals lit?
Trying to decide whether or not to pull the trigger but have never seen them lit up...
Thanks a million!
Old Apr 1, 2008 | 08:07 PM
John S.'s Avatar
John S.
Thanks a million!
I dont have a pic of them lit up but i had the red/clears on my z06 and I am looking to put a set on my frc now as well. They are great additions to the car and are bright. You will not be disappointed!
Bill Vett's Avatar
Bill Vett
I have them on my car but I don't have any night pics. The red lights are like the stock lights. When you turn on your lights they light. When you hit the brakes the get bright. The lower lights are your turn signal light. They flash amber.
Old Apr 1, 2008 | 08:16 PM
YO-EL's Avatar
YO-EL
This set is for sale, as well as clear corners:
(yea yea, hijack,,, but I'm allowed...)
Old Apr 2, 2008 | 06:19 AM
FinnZ06's Avatar
FinnZ06
Here you go..
Ignore the fog lights..
Old Apr 2, 2008 | 06:34 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Unless you leave them wired incorrectly, then the yellows come on when you hit your brakes along with the red, but only the yellow flashes when you put the turn signal on. If you apply the brakes with the turn signal on the red shines solid but the yellow flashes.
HTH
Old Apr 2, 2008 | 06:38 AM
zonsolo's Avatar
zonsolo
Originally Posted by FinnZ06
Here you go..
Sick clean garage you have there my friend!
Old Apr 2, 2008 | 07:05 AM
John S.'s Avatar
John S.
HTH
the yellows shouldn't come on with the brake. did you cut the white wire under the dash near the brake pedal?
Old Apr 2, 2008 | 08:25 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
Here you go..
there it is guys!!!! my next mod. amber signal lights on the outboard lights, move the back up lamps to the inboard, and fabricate a panel to eliminate the current back up lights.
the fog lights........uhhhh........ maybe not
thanks FinnZ06
Old Apr 2, 2008 | 09:27 AM
DeeGee's Avatar
DeeGee
HTH
Whoever did your mod didn't snip the white wire under the dash. When you do that it seperates the turns from the stops and they work independently. You shouldn't get ambers when you hit the brakes if the mod is done right. Check the installation instructions on PFYC.com and you'll see a pic of the wire.
Old Apr 2, 2008 | 10:30 AM
Mister Peebody
Default To Each His Own...
I actually prefer it this way. Thanks for the advice though. I figure the more attention the rear end gets the less likely someone will run into it. The turn signals still function properly. I did note in my original post that my lights are wired incorrectly, by the way.
Old Apr 2, 2008 | 12:34 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
thanks FinnZ06
There is no panel to fabricate, you can buy that part from GM.
I have one in my garage that I never used.
If you were close I'd give it to you.
Old Apr 2, 2008 | 01:01 PM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
Old Apr 2, 2008 | 02:02 PM
NITRO UK's Avatar
NITRO UK
hi matey.
i reckon im the only english guy that cant help you,but im sure there`s
uk boys that can.i would offer a pic of mine,but this thread could go bad for ya.hope you get it sorted. nitro uk.
Old Apr 2, 2008 | 03:21 PM
Bill Vett's Avatar
Bill Vett
I don't know what your lighting laws are in Texas but I think that red is the only acceptable color for stop lights. In Pa. we have major restrictions on lighting for inspection.
Old Apr 2, 2008 | 03:40 PM
Plentyfast's Avatar
Plentyfast
Old Apr 2, 2008 | 07:37 PM
10U 99's Avatar
10U 99
thank you sir, I ordered one this afternoon
To Euro tails?....
Old Apr 2, 2008 | 08:00 PM
Tannman's Avatar
Tannman
HTH
Old Apr 4, 2008 | 10:56 AM
tbrent's Avatar
tbrent
Thanks for the pics and info! They look really good lit up! Now I'm thinkin about the back up light panel mod too
Old Apr 4, 2008 | 10:58 AM
02MillenniumVette's Avatar
02MillenniumVette
thanks FinnZ06
The Tigershark rear fascia will do all of that for you.
