I know theres a quite a few guys with 19" rims up front. Is anybody having any issues with rubbing the inner front wheelwell on a 255/35/19? I never heard of anybody having any problems with this size tire. In fact, that tire size is recomended by the vendor that sells these wheels but I get a rubbing when I make a sharp turn. If I turn the wheel sharp to the right the outer lip of the left tire will rub the front of the wheelwell I believe. Can this be fixed with a smaller tire?
People run wider tires than 255 w/ that profile and diameter without problems, so I'm thinking the problem is with your wheel's offset and/or backspacing.
I just chcked, they are 265 not 255. I will email the vendor that sold them to see what th offsets are. Would going to a 255 or 245 help with an offset problem? Or will going to a 30 instead of a 35 in the front help at all?
I'm running 265/35/18 in front with no problem at all, and 305/30/19 in the rear. The overall roll out is the same as a stock Z06. No traction control or ABS codes and no rubbing. I'm running the proper offset for a C5. Here's the proper offset you need..56mm in front, and 63mm in back
I don't think you can simply declare a particular offset as being the right one all the time; wouldn't the width of the wheel (and with different width wheels) determine the proper offset?
Yes you can.... You should be with in +- 3mm of the stock offset. The only time it would be different from stock is a 12" wide rim. You would either have to tub the car or flair the fenders for them to fit in the rear. Do a search using "offset"
The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel. It can thus be either positive or negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork.
Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
"Deep dish" wheels typically have negative offset or a very low positive offset.
To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car manufacturer's original offset should be maintained when choosing new wheels unless there are overriding clearance issues.
Wheels are usually stamped with their offset using the German prefix "ET", meaning "Einpresstiefe" or, literally, "insertion depth". An example would be "ET45" for a 45mm offset.
Calculating the offset of a wheel is a fairly easy mathematical equation. First, measure the overall width of the wheel (remember, just because a wheel is 18x7.5, does not mean that the OVERALL width is 7.5”. It means that the measurement between the outboard flange and the inboard flange is 7.5”). Next, divide that width of the wheel by two; this will give you the centerline of the wheel.
Overall width/2 = Centerline
After determining the centerline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground – face up – your measurement would be from the ground to the hub-mounting surface). This is your back spacing.
Back Spacing - Centerline = Offset in Inches
Inches x 25.4 = Offset in mm
