jacking question
Old Apr 6, 2008 | 09:49 AM
cedge's Avatar
cedge
Default jacking question
had to change a flat,used pump jack just on pass. rear. should i have lifted the whole side or rear of the car.
Old Apr 6, 2008 | 10:02 AM
Oldvetter's Avatar
Oldvetter
Nope, you did good.
The C5 has one of the stiffest frames, it is hydroformed. It uses a multi-million dollar piece of equipment which pressurizes one long steel tube to make a one piece frame rail. Most cars use many welds on many pieces to make a frame rail (thought you would want the details, from one engineer to another). No need to open (or not open) doors or take off (or install) Targa Top when jacking either, these were for older Corvettes.
If I may ask, did you have non-runflats, and if so, what jack did you use?
Old Apr 6, 2008 | 10:20 AM
cedge's Avatar
cedge
Originally Posted by Oldvetter
Nope, you did good.
thank you for the exact answer i was looking for. noticed a large nail in the sidewall after the car was put up for the winter.just thought i would take care of it now. had to buy new tire no one would fix it.
Old Apr 6, 2008 | 10:39 AM
cedge's Avatar
cedge
forgot about the jack. i use a 2 ton furious jack from nappa, duel piston, great jack. paid 200.00
Old Apr 6, 2008 | 10:40 AM
robsc501's Avatar
robsc501
Hi Cedge,
I f you only took a few hours to change the wheel & had the one side supported with additional jack stand & wood blocks covering both cross members on that side then you will have no problems as the suspension & the body is tough& flexible.I think on the older vettes the bodies were not as flexible as the c5 and if you made a habit out of just jacking one side it would have stressed the body around the door area, thus having a misaligned door & air leaks.
When I,am going to have my rear up or the front. I use both my floor jacks & raise both sides evenly,but thats just my way.
Tip: If your wheel needed to be balanced make sure the the new weight they put on the wheel is not a lead one. Needs to be polyester coated to prevent corrosion. Torque wheel nuts in a star pattern at 25lbs. increments, final torque is 100ft. lbs. Good time to check wheel axle nut torque(118ft.lbs.) requires a 34 mm socket
robsc501
Old Apr 6, 2008 | 11:01 AM
cedge's Avatar
cedge
Originally Posted by robsc501
Hi Cedge,
robsc501
thanks for the info, especially torques, and they did use the polyester coated weights to balance.
Old Apr 6, 2008 | 12:30 PM
DeeGee's Avatar
DeeGee
You got some great advice . This may help for future reference:
Old Apr 6, 2008 | 01:56 PM
cedge's Avatar
cedge
thanks, i got it all now. the car has never had a problem, never a reason to jack it up.
To jacking question
