Wiper Arm Removal
Old Apr 7, 2008 | 10:17 AM
hayman's Avatar
hayman
Default Wiper Arm Removal
Anyone have trouble removing the windshield wiper arms? I had a little trouble removing the driers side but the passenger side will not pop off. Is there a special tool available?
Bill
Old Apr 7, 2008 | 10:49 AM
littleed's Avatar
littleed
yeah there is advanced has one iyts cheap. Im pretty sure u have to move them from the stowed position to unlock them and then lift up to unlock them thtas how i did mine. I just marked their position on the windsheild wiht tape. also od a search i ofund allot of great info to help me out on the site to do it.
Old Apr 7, 2008 | 10:53 AM
Bob CTS's Avatar
Bob CTS
I had to let some WD40 soak over night and that allowed it to pop off. I lifted the blade portion and then rocked the base a bit. Popped right off.
Old Apr 7, 2008 | 11:55 AM
TraceZ's Avatar
TraceZ
I removed mine a while back to clean under the cowl trim. I left them in the park position, removed the plastic caps and nuts, hit them with a little PB Blaster and rocked them off.
Have you tried spraying them with something to help loosen them up?
Don't pry against the windshield, it breaks easily.
Old Apr 7, 2008 | 12:48 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
This thread here shows you all the tools and the process to remove the wiper arm:
http://forums.corvetteforum.com/show....php?t=1715595
To Wiper Arm Removal
