[Z06] Polishing ti
Old Apr 7, 2008 | 07:17 PM
bobdobb's Avatar
bobdobb
Default Polishing ti
I am thinking about polishing the muflers since they are so visable. Has anyone here done this? What did you use? Can you post a picture please. I started cleaning and found that 0000 steel wool make them look very shiney, and I like shiney. I would really like to futher this process.
Old Apr 7, 2008 | 08:03 PM
meldog21's Avatar
meldog21
I haven't done the car mufflers but I did the ti exhaust bracket on my motorcycle. I just used the normal fine compounds on my buffing wheel(green then white). It came out great. I guess you could do the mufflers, but it would be a lot of work.
Dog
Old Apr 7, 2008 | 08:41 PM
slong's Avatar
slong
Let’s see. Remove and start with 9 micron paper- day or two to complete. Then start with the green compound and work your way to white, and then finish with yellow at low speed. Don't forget to change out each wheel for contamination reasons. After that float with an electro-polisher, but go DC first to pull the excess compounds back out of the metal, passivation is a good thing. Then hit it with AC to knock off the mountain tops but be sure to flood the chemical in the process. Or if you don’t want medical grade, just use your favorite metal polish like Mothers and rub them out. By the way, great color!
Old Apr 7, 2008 | 08:47 PM
LT1GMC's Avatar
LT1GMC
Do NOT use steel wool, you will imbed tiny particles of steel in the metal, which will cause rust spots at the first sign of moisture. That goes for Ti, SS, Aluminum or anything.
Old Apr 7, 2008 | 09:28 PM
Bigstik's Avatar
Bigstik
Get some Mother's polish and one of the mini-***** for a drill. works like a charm and is comletely safe for the Ti tips.
not the best pic but its all I got right now.
Old Apr 7, 2008 | 09:31 PM
tlc0706's Avatar
tlc0706
Whoaaaa....that's a good tip
Old Apr 8, 2008 | 01:37 PM
YellowZed's Avatar
YellowZed
Solvol Autosol and a dry rag. 5 minutes once every few weeks and the exhaust tips shine up great.
Old Apr 8, 2008 | 06:55 PM
MattZ28's Avatar
MattZ28
Guys he's talking about polishing the mufflers themselves...not the tips.
Old Apr 8, 2008 | 06:56 PM
bobdobb's Avatar
bobdobb
Not the tips. They are fine. I am talking about the mufflers.
Old Apr 8, 2008 | 07:01 PM
Bigstik's Avatar
Bigstik
I still say mothers with the mini ball
Old Apr 9, 2008 | 02:06 AM
Novat_99's Avatar
Novat_99
Not the best pic...but, I used Mother's on mine & it worked out great
Old Apr 9, 2008 | 10:04 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
I started out with Simichrome Polish and then used Mothers to bring out the shine.
Old Apr 9, 2008 | 10:42 PM
bobdobb's Avatar
bobdobb
Damm thats clean! I can't wait to get the truck back on the road and start cleaning. It's a daily driver until then.
To Polishing ti
