Intake Manifold ?
Old Apr 8, 2008 | 02:04 PM
bucknutt76's Avatar
bucknutt76
Default Intake Manifold ?
So I am going to install a weind intake manifold on my 04 soon. My buddy tells me when he did it to his mustang he had to replace the injector o rings. I dont know anything about this but I do know they are hard to find. I was wondering if anyone had any experience with this and if they had to replace theres so it wouldnt leak fuel. Thanks alot for any info that you may have.
Chadd
Old Apr 8, 2008 | 02:45 PM
bucknutt76's Avatar
bucknutt76
ttt
Old Apr 8, 2008 | 02:50 PM
slow98cobra's Avatar
slow98cobra
When I changed intakes on my stang, which is probably basicly the same as the ls1, I actually reused my o-rings but it is probably not recommended. Just make sure you put some spit on the orings or lubricate them before reinstalling or you will tear the o-ring and may not know it. Learned this the hard way on my old 88 GT and started it up to spray a little fuel in the motor compartment.
Old Apr 8, 2008 | 02:58 PM
bucwheat's Avatar
bucwheat
Originally Posted by bucknutt76
ttt
KKK
Old Apr 8, 2008 | 03:18 PM
bucknutt76's Avatar
bucknutt76
Originally Posted by bucwheat
KKK
WTF? Is this
Old Apr 8, 2008 | 05:41 PM
GRUNIE's Avatar
GRUNIE
Be carful not to screw yourself with a Weind manifold when it comes to the visual on emissions inspections. You may pass the sniffer but if they see an after market manifold, you will fail. Isn't great to own a modded Corvette in Kalifornia?
Old Apr 8, 2008 | 08:03 PM
bucknutt76's Avatar
bucknutt76
good point, i should change the reg. back to ohio
To Intake Manifold ?
