help me out...mod
Old Apr 8, 2008 | 10:30 PM
memphis_vette's Avatar
memphis_vette
Default help me out...mod
the mass air flow housing is on the air intake correct i have a blackwing so does it come with a air flow housing for BW or do u stick stock one on? and if so is it worth it...its pretty cheap
http://www.mamotorworks.com/corvette-2-230-677.html
Old Apr 8, 2008 | 10:38 PM
memphis_vette
help?
Old Apr 8, 2008 | 10:43 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
If it was me I would not buy an aftermarket one, I would just get on fleabay and purchase an 01-04 MAF that is what I did and works just great on your model Vette had mine on for 13k now
Old Apr 8, 2008 | 10:47 PM
memphis_vette
could u pointmein the right direction on ebay?
Old Apr 8, 2008 | 10:49 PM
memphis_vette
and im not sure where it is...is it where the air filter of the blackwing then it goes to mass air flow housing then to the intake manifold correct...when u buy a blackwing does it come with a MAH for blackwing or is it still the stock vette
Old Apr 8, 2008 | 11:02 PM
memphis_vette
need some support
Old Apr 8, 2008 | 11:14 PM
02MillenniumVette's Avatar
02MillenniumVette
Dont waste your money on an aftermarket MAF. You gain, if your lucky, at most 1-2hp from an aftermarket MAF.
The stock MAF will hook directly up to the blackwing. It will be the blackwing, MAF, air bridge, throttle body, then intake.
Old Apr 8, 2008 | 11:16 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
need some support
Here your go, looks like the one I got
http://cgi.ebay.com/ebaymotors/MAF-M...em310038560186
Old Apr 8, 2008 | 11:37 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I have the one from MAM....but i got it off fleabay for $20. Me Gusta
Old Apr 8, 2008 | 11:46 PM
memphis_vette
and that will fit a blackwing on a 98 c5
Old Apr 8, 2008 | 11:47 PM
memphis_vette
which is better for price? mam or delphi...how much estimated hp gains
Old Apr 9, 2008 | 12:15 AM
memphis_vette
probably gunna order tonight need a final
Old Apr 9, 2008 | 12:19 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Probably about the same, I got the GM one as that was the only ones on fleabay at the time I did my setup 2 1/2 years ago
Old Apr 9, 2008 | 12:51 AM
memphis_vette
and it will positively fit a 98 c5 with blackwing...i just dont wanna buy and get sumthan that doesnt work
Old Apr 9, 2008 | 12:59 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Seems to work fine on my setup and I have a little more than a black wing
Old Apr 9, 2008 | 01:03 AM
ljthe2nd's Avatar
ljthe2nd
Why do you want to buy a new MAF sensor? Is there something wrong with the one on the car now? If not, don't waste your money on another one or an aftermarket one. You will not notice any gain in HP and you could possibly cause it to run worse
Old Apr 9, 2008 | 04:34 AM
Lancejoker's Avatar
Lancejoker
And seriously,what's with the new question every 3 minutes? Post it all in one
Old Apr 11, 2008 | 08:34 PM
boattrash9's Avatar
boattrash9
Default I plan on buying this upgrade as well
As for all of the people who don't agree with this mod I still have yet to see ONE person that ACTUALLY bought it and installed it and had problems. I am not saying it isn't possible but no one on here yet.
As for the mod I think it is worth trying just for a couple of reasons.
One being the the same old saying is true ..More Air= More Power. This would eliminate at least one bottleneck and the claims that it will flow over 1000cfm vs stock six hundred and something.
Two...If it doesn't work....Simply install your MAF sensor back into the original housing and wow...You are out of 30 or 40 dollars. I don't see any reason why it could possibly hurt.
I know there has been discussion about the screen removal of a MAF sensor...I understand that the fins route the proper air flow over the sensor so maybe this could be some kind of a problem to look into.
I would love to hear how it goes for you and goodluck!!
Old Apr 11, 2008 | 08:57 PM
memphis_vette
thx i am still deciding lol but i will probably just try anyways whats 40 bucks
To help me out...mod
