Headlight problem
Old Apr 9, 2008 | 11:41 AM
04DevilR1's Avatar
04DevilR1
Default Headlight problem
Head light on one side goes up and down with no problem. the other will go up fine, but when it lowers back down it keeps spinning the motor after its down. I have to stop the motor by hand? What is wrong with this thing?
Old Apr 9, 2008 | 11:58 AM
2fast4sanity's Avatar
2fast4sanity
It's a stripped headlight motor gear. GM puts cheap plastic gears in the motors that WILL strip over time. It's a relatively easy fix. Go to www.rodneydickman.com and buy a set of brass headlight gears. This will fix your one headlight and prevent the same from happening to the other side. There are a myriad of posts on this subject if you're looking for more info.
Old Apr 9, 2008 | 12:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Time for a new gear
Old Apr 9, 2008 | 01:25 PM
silverbullit99's Avatar
silverbullit99
That's new gear replacement.. It's not as hard as it looks. if you are going to change one,, change both. And get the brass ones, will last forever.
Old Apr 9, 2008 | 01:29 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
You won't regret it
Old Apr 9, 2008 | 06:11 PM
04DevilR1's Avatar
04DevilR1
sweet just ordered the brass ones, anyone wanna give me some quick instructions for installation or do the gears come with that???
Old Apr 9, 2008 | 06:15 PM
02MillenniumVette's Avatar
02MillenniumVette
http://forums.corvetteforum.com/show...76&postcount=8
Old Apr 9, 2008 | 06:23 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Couple tips -
-when you get the motor open clean out the little gear box good.
-when you get the headlight cover and side cover off take out the two little screws on the side of where the headlight pivots. Then you can drop it down below and get to the motor easy. Remember the position of the lever to the motor and the headlight. Clamped mine overnight and don't forget to put the T brace on that comes with the kit.
Old Apr 10, 2008 | 10:53 AM
2fast4sanity
Instructions are included with the gears.
Old Apr 10, 2008 | 12:37 PM
silverbullit99
Default Instructions for changing the light gears
http://forums.corvetteforum.com/show....php?t=1767764
To Headlight problem
