Running Hot ?
Old Apr 9, 2008 | 01:49 PM
Fly-N-LOw's Avatar
Fly-N-LOw
Default Running Hot ?
When I'm cruising the coolant tenp is 190-195 when I stop
for something then start up it goes to 220. When I get in stop and go traffic the same thing. Coolant is full,30000 miles. Had to put in about a gallon of water last yr because top of tank came loose. Any help on what to do would be appreciated.
Old Apr 9, 2008 | 01:50 PM
Army08's Avatar
Army08
Old Apr 9, 2008 | 01:53 PM
Torch FRC's Avatar
Torch FRC
I have the same issue.
Old Apr 9, 2008 | 01:56 PM
damilleniumboy's Avatar
damilleniumboy
If you blow/wash your radator it will help keep the temps a bit lower. The airdam works like a vacuum, and every little piece of junk gets stucked in the radiator.
Old Apr 9, 2008 | 02:02 PM
MagRedConv's Avatar
MagRedConv
Just went through mine last week. BTW, there's a fan controller on the parts board if that's an avenue you'd like to travel.
Old Apr 9, 2008 | 02:07 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
My guess is that you have a sticking thermostat. I recently ran into the same symptoms as you're having in my WS6 LS1 Trans-Am. Changed out the stat, now all is good.
Here is my (NON-EXPERT) view.
When the stat doesn't open all the way, it restricts coolant flow to the radiator. At higher rpms (highway speeds), enough coolant volume is pumping through the system to cool the temps. At lower RPM not enough coolant is getting through the rad becuase on the partially closed stat to cool efficeintly.
Good luck.
Silverbird
Old Apr 9, 2008 | 02:30 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
This is quite normal and not anything to worry about. The LS1 was designed to run hotter than most are used to seeing in other cars. BTW do NOT put anything other than mix of Dexcool or a comparable coolant that meets GM specs and water in you surge tank or you will be buying a motor.
Old Apr 9, 2008 | 05:11 PM
Those really aren't bad temps. But I do agree with checking to make sure that the radiator area is clear of debris.
Old Apr 9, 2008 | 05:58 PM
robsc501's Avatar
robsc501
Default Running Hot?
Hi there,
Those temperatures are in the normal range for the ls1 engine.Thermostats made today either work or they don't. Yours appears to be working.If your radiator is clean you might want to consider adding 2 bottles of water wetter available from auto zone.Note: When you add water to the surge tank it should be distilled water.If your radiator is full of debris (leaves etc.) you may want to consider installing a radiator screen from eliteengineeeringusa.com custom fit easy to install. I did & it keeps most of the junk & damaging rocks out of the front of my radiator about 100 dollars.
Hopes this helps you retired guy.
robsc501
Old Apr 9, 2008 | 06:00 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Normal Op temps...
Peace
Chip
__________________
..................Click for
Old Apr 9, 2008 | 06:17 PM
Chemdawg99's Avatar
Chemdawg99
but like I said, the temps you are experiencing are normal.
Old Apr 10, 2008 | 12:07 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Our Vettes made to run hot and they are bottom feeders and I always clean out my radiator area every oil change
Old Apr 10, 2008 | 12:21 AM
mbroadway's Avatar
mbroadway
Default I read...
I remember reading somewhere that 254 degrees was the "danger" point. If the coolant temperature in the LS1 reaches that point, the engine starts firing on only 4 cylinders (I know that sounds strange, but I don't think I dreamed it.) I don't know what the purpose of that is other than to possibly decrease the friction that's taking place in the engine overall and allow the coolant to cool down.
Correct me if I'm wrong. I don't mind.
Michael in KC
Old Apr 10, 2008 | 12:43 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
the first time on a lift I found weeds, leaves, a feather, and a candy wrapper
To Running Hot ?
