TPS and FOB sensor replacement - Help
Glen
first off, it can be tricky programing the TPS's if you don't have a strong enough magnet. You need to make sure you place the magnet at the base of the Valve Stem. You might have to move it around a bit. I assume your waitihg for the prompt on the dic.
On your fob, are you sure you have a new battery in the fob? And is it in the right way? I had a problem with mine that the side contact had moved on me when I put the new battery in.
Good luck.
http://cgi.ebay.com/ebaymotors/97-00...spagenameZWDVW
The module that receives the signals from both the TPS and the fobs for the remote locking is called the Remote function actuation module (RFA) also known as the remote control door lock receiver (RCDLR)The way the system works is that when the power is on and the vehicle is moving the TPS send a radio signal to the RDCLR which turns that signal into location and pressure info and sends it to the BCM. If it doesn't see a signal after 8 seconds it sets a code. Obviously, the fob also sends a command and the RCDLR operates the door lock modules.
Firstly is it throwing any codes? You'd get different codes for which element is at fault. If an individual sensor was at fault you'd get XXX on that sensor. If the fobs were at fault the TPS should work and you say you haven't changed those. The only way both would be at fault is if you had the wrong TPSs and fobs (00 onwards spec) or the module was down.
If you're sure you've reprogramed the fobs and TPS correctly, logically, the fact that both are not working says to me that the RFA is the problem. It makes sense because each system has a different programming method. I could see one not programming but both seems unusual.
As you say, it sits in the rear passenger compartment on the drivers side. If you decide to try it, the replacement is easy:
Ignition off
Remove rear left compartment insulator
Pull on the retainer at the back side of the receiver
Pull out the receiver enough to see the connector
Disconnect the connector and remove
Connect the receiver
Line up the receiver with the slots in the retainer
Snap the receiver into place
Reinstall the insulator
Reprogram the fobs and TPS
As already suggested, make sure you get the correct RFA for your car. The older models has a different RFA which works at a different frequency. If the fobs, sensors and RFA are not matched the system wont work. I know Gene always asks for the VIN so I assume you have right parts.
I used a little magnet that's on the end of a telescope tube like a pointer. Can get them at most auto stores. Check it to see it's a strong one....the use them to pick up bolts etc when you drop them around the engine etc.
