Turning off auto lights
Old Apr 10, 2008 | 08:17 PM
3Xvette's Avatar
3Xvette
Default Turning off auto lights
Question guys i have a 2000 corvette and i hate when the lights flip up and come on. I want to be in control of turning ligts on and off. Example start car in garage head lights come on back out, lights go off.Is my only way to take it to the GM dealer and get them to disable this or do i buy this thing called a defeat device.You would sure think there would be a on off switch for this.
Old Apr 10, 2008 | 08:24 PM
krm_wi_C5's Avatar
krm_wi_C5
You have a Canadian car, there is no way to simply turn them off. You can pull a fuse, not sure which one it is on your year car, or you can buy a pre-made resistor, which I did, and it works great. Here is the link:
http://www.corvettegadgetman.com/
It is an approx 30 minute install, you pry up the grill at the back of the dash and attach the wires from the resistor to the wires on the twilight sentinel sensor with clips supplied with the resistor, then tuck into place and put the grill back on. You have to be somewhat careful when prying the grill up, I used an old credit card. It just takes a little time and patience. Good luck!
Old Apr 10, 2008 | 08:30 PM
EPMM 03 C5's Avatar
EPMM 03 C5
i think it's fuse 20 under the hood...there was a post about this same thing about 6 months ago. i know what you mean i'm about to pull my fuse too!!
eric
Old Apr 10, 2008 | 08:36 PM
3Xvette's Avatar
3Xvette
eric
I wonder if pulling that fuse, if it effects anything else? I just looked at my manual and fuse 20 under the hood is showing Blank
Old Apr 10, 2008 | 08:53 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Your vette has the twilight sentinel option. If it was originally a Canadian vehicle you cannot turn off this option. I guess you will have to follow the previous postings to pull the fuse.
Old Apr 10, 2008 | 09:11 PM
RonJ's Avatar
RonJ
The fuse that has to be pulled is under the floor mat. It's either #24 or #42, I don't remember. I'd have to pull the carpet up and look.
Once it's pulled, no more automatic pop-up and you have to turn the lights on and off by hand.
RonJ ...
I went out and looked, it's Micro Relay #44 under the carpet.
Old Apr 10, 2008 | 09:15 PM
3Xvette's Avatar
3Xvette
RonJ ...
Thanks Ron #24 is Radio Antenna and #42 is Micro Relay Courtesy Lamps i will try this.
Steve,
Old Apr 10, 2008 | 09:31 PM
RonJ's Avatar
RonJ
Steve,
I went out to the shop, lowered the 01 on the hoist and pulled the carpet.
It's Micro Relay #44, which by the owners handbook is for the Automatic Lamp Control Headlamps.
RonJ ...
Old Apr 10, 2008 | 09:34 PM
EPMM 03 C5's Avatar
EPMM 03 C5
pull up the carpet??!! i'm guessing the drivers side?
eric
Old Apr 10, 2008 | 09:42 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Hi..I had the same issue...purchased the headlight defeat from
(http://www.corvettegadgetman.com/)...works great and an easy install...solved the issue...if you need a hand let me know, I'm not far from you..
Old Apr 10, 2008 | 09:49 PM
3Xvette's Avatar
3Xvette
RonJ ...
RonJ i see the relay #44 ALC HDLP does this just pull out i really pulled on it and it doesn't want to come Omron relay.
Old Apr 10, 2008 | 09:52 PM
3Xvette's Avatar
3Xvette
Thanks HiVoltage if the relay being pulled doesn't work that is what i'll do headlight defeat and pm you for some help if you don't mind.
Steve
Old Apr 10, 2008 | 09:54 PM
RonJ's Avatar
RonJ
You might have to wiggle and pull, it does come out.
Once I removed mine, I wrapped it up, wrote #44 on it and left it along side the fuse panel under the "door" just so I wouldn't lose it.
And Eric, it's on the passenger side under the toe board.
RonJ ...
Old Apr 10, 2008 | 10:07 PM
3Xvette's Avatar
3Xvette
Thanks RonJ pulled the relay and works perfect thanks man.
Old Apr 10, 2008 | 10:32 PM
RonJ's Avatar
RonJ
Good of you to post back that it worked, a lot of people wouldn't.
RonJ ...
Old Jul 12, 2008 | 03:53 PM
NTMD8R's Avatar
NTMD8R
Another simpler/faster/cheaper fix, which will NOT affect anything else
http://forums.corvetteforum.com/show...light+sentinel
post # 24.
Old Jul 12, 2008 | 05:06 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/show....php?t=2029907
To Turning off auto lights
