oilly throttle body
Old Apr 11, 2008 | 05:27 PM
bugsas99's Avatar
bugsas99
Default oilly throttle body
for awhile after car came up to temp and when i came to a stop i could smell oil burning not bad but noticeable. well today i was going to clean my throttle body for something to do. and after removeing the factory plastic ribbed looking duct that goes to throttle body. i noticed some oil laying on bottom of plastic duct. and i opened the valve on throttle body to inspect and outside was pretty clean on inside it was quite oilly covered i thought. i'm guessing this isn't normal. what would cause there to be oil on throttle body and is this bad for motor. and what fix would be in order. car is a 98 and has 75,000 miles on it. and runs rather well i think. any input???
Old Apr 11, 2008 | 05:37 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
did you just re-oil your air filter?
Old Apr 11, 2008 | 05:38 PM
bugsas99's Avatar
bugsas99
no useing factory filter and box right now..
Old Apr 11, 2008 | 06:42 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
You should see how much is in your intake. I put a catch can on mine and drain it a few times a year
Old Apr 11, 2008 | 07:57 PM
rws.1's Avatar
rws.1
LSx engines are known for oil misting in the rockers..
the mist carries over and gets deposited in the throttle body, intake ando on piston heads...
Many install an oil catch can to minimize this issue.
Old Apr 11, 2008 | 08:10 PM
Dave68's Avatar
Dave68
You might want to read PCV Line Oil Removal, 101, located here:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Give it a read before you order anything. It just might keep your intake all the cleaner!
Old Apr 11, 2008 | 08:41 PM
dobewillie's Avatar
dobewillie
thanks for the link Dave
Old Apr 11, 2008 | 09:44 PM
Dave68's Avatar
Dave68
I hope it helps!
Dave
Old Apr 11, 2008 | 10:38 PM
oaks99's Avatar
oaks99
get a hold of chip ( willfulone ) and order your catch can
oak
Old Apr 11, 2008 | 11:29 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
oak
Help is just a click away
http://www.customcorvetteaccessories...lcatchcan.html
Peace
Chip
__________________
..................Click for
Old Apr 12, 2008 | 09:12 AM
ALVETTE00's Avatar
ALVETTE00
Peace
Chip
Hey Chip...is there a # i can reach you at...have a few ? on the catch can?
Thanks,
al
Old Apr 12, 2008 | 06:24 PM
CCA Corvette Parts
Thanks,
al
http://www.customcorvetteaccessories.com/contactus.html
Peace
Chip
Old Apr 12, 2008 | 08:10 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
oak
Must have getting a catch can for our LS based motors, got one on my boosted setup and it works wonders, last fall took off the throttle body to clean it better and no oil in my intake
Old Apr 13, 2008 | 09:58 AM
B-Vette's Avatar
B-Vette
I agree with the guys on the catch can. I had my Throttle Body off for porting and ordered a catch can immediately when I noticed the oil in it.
To oilly throttle body
