I replaced belts and tensioner, ac belt twice within 2 weeks tried belt dressing and wd40 still squeaked. went to autozone bought new liquid wrench silicone spray. no squeak for 3 months so far with only one spray.
I brought my car to the dealership today to follow up on a chronic belt chirping problem. The technician put some GM engine silicone sealant (comes in a tube) on the main belt. The chirping stopped immediately. The technician said serp belts tend to get glazed, which is sometimes the cause of chirping. He also said that it wasn't a permanent fix, but should be effective for an "extended period.
I would NOT recommend the engine silicone sealant for fixing chirping problems. The chirping came back the next day. The sealant seemed to leave pasty splotches on a few pulleys, which I had to clean before installing a new belt -- AZ Gatorback (The Quiet Belt). The installation was a little tricky. But not as bad as I thought it would be. It took around 30 minutes. Chirping is gone for now
While under warranty, took to dealer. Replaced water pump and new AC Delco belt. Lasted all of 30 minutes. Next they replaced all 4 idlers/tensioners and another new belt. That lasted 2 days. Back in again and they replaced the harmonic balancer and put on new belt.
That did the trick! At least until a month or so ago and now it's back on humid coolish day startup. Goes away within a minute or two. Has had a Gatorback belt on for 3 months, so am surprised the chirp is back.
Only thing left in my case is the alternator or power steering pump. My inclination is the alternator... have read some here have found the squeak there as well.
It's a devil to chase down. very hard to isolate exactly where it's coming from even when using the tried and true 'hear-stick' method.
And there is the beginning of a misdiagnoses, a rape, and a bad taste left in your mouth. With the amount of threads on this forum about squeaky belts, I would NEVER take this problem to a dealer. If the transmission falls out the car, I might pause and think about it but Patches has a thread where he removed his entire drive train. I'd rather over pay him to fix it than to trust those dweebs at the stealership.
Actually, I completely agree. Since the late 60s, when I owned a British sports car, I swore I would never let a “dealership” lay a wrench on any of my cars ever again.
Tried and trusted means of trying to isolate a sound.
Use a plain ole ordinary broom with wooden stick or a yard stick or any other suitable stick of wood. Place one end on the area you want to listen to, then hold the other end of the stick up to your ear. Use CAUTION not to let the stick get caught in any moving parts!!! Amazing what you will hear.. Try it all over the place... can even hear valve train, injectors clicking, bearings, or virtually any other noise made by rotating parts.
A poor man's stethoscope......
Wow, I didn't know that. Another things learned while surfing CF!
Mine squeaks like h*ll on start up if it has been raining or it is damp outside. It will stop once I get moving and wind out first gear though. I don't pay it any attention.
Another bit of trivia.....If you have a tuning fork or know someone that does... stick a finger in your ear, then pop the tuning fork and place it on your elbow bone.. You will hear perfectly the note from the tuning fork in your ear being transferred via your bones!
Same here. When it rains or it's damps my 2000 will sometimes squeak until the engine is warm.
If it were a pulley, then it should squeak all the time, so it tells me it's the belt. The belt isn't worn and the sound goes away very quickly. I just ignore it.
Maybe it's loose?
I had the same problem. Followed the tip to isolate which belt drive was the culpret. As it turned out it was the main drive. The belt checked out ok. Then I bought BOTH the tensioned and idler. 45 minutes later I'm on the road without a squeek or chirp.
I'm having a belt problem now myself (serpentine) and I've replaced the tensioner and gone through 3 different manufacturers belts. A new belt will stop the problem for awhile but it aways comes back, usually after a long trip.
Once the squeak manifests itself again I have a constant squeak on cold start up and it continues after the engine is warmed up. Squeak does not go away and belt eventually gets "glazed" on it's backside. Belt sides and grooves are in near perfect condition (except for the glazing on the backside as mentioned). I'm going to try changing the Idler pulley next.
