Remove splashed paint?
Old Apr 13, 2008 | 10:19 AM
vettesrm's Avatar
vettesrm
Default Remove splashed paint?
I was on the highway and drove through an area where someone had spilled some paint.
It resulted in what looks like light over-spray of paint in the wheel wheels and on the bottom of the car along the doors, much like when you get dirt & grim splashed up when you pass through a puddle of water.
I was going to use the clay bar from Zanio but was wondering if there is something else I might use that may be a little easier but but not harm the paint job on the vette.
Shawn in Houston
Old Apr 13, 2008 | 10:20 AM
DeeGee's Avatar
DeeGee
I was thinking clay bar for starters Shawn
Old Apr 13, 2008 | 10:24 AM
vettesrm's Avatar
vettesrm
I feel safe with the clay bar on the paint and it probably would work, but the wheel wells could probably withstand something simple that wipes on and off.
Old Apr 13, 2008 | 11:38 AM
jrose7004's Avatar
jrose7004
I'd start with claybar.
Old Apr 13, 2008 | 11:46 AM
Mike McCoy's Avatar
Mike McCoy
Stop at your local paint store and check the instructions and cautions for a product called "Goof Off". It might work for you.
Old Apr 13, 2008 | 12:06 PM
91LSMAN's Avatar
91LSMAN
I would use claybar on the paint as was already mentioned.
For the wheel wells, try degreaser and WD-40. I have even heard of people getting overspray/roadspray off paint with WD-40.
Good Luck.
Old Apr 13, 2008 | 01:10 PM
hotwheels57's Avatar
hotwheels57
Denatured alcohol will not harm your paint...followed up with a clay bar. I've used this manner to remove enamel pin striping paint on several occasions w/o harm to base coat/clear coat.
If the paint was water based, use water as your first plan of attack. Mineral spirits/turpentine might also be an option, but test on paint first in an inconspicuous area.
If the paint was the type used on roadway stripes, be careful, it's silica based and scraping anything across it might do harm to paint.
Old Apr 13, 2008 | 01:12 PM
Fast Cop's Avatar
Fast Cop
For cleaning inside the wheel wells I have used simple green and a brush for normal cleaning and for paint splatter like you listed I have used the simple green with a steel wool pad, worked great.
To Remove splashed paint?
