I want to make a partition for my 2002 convertible. I am going to make it out of MDF and I want to screw it in. I know I can screw it in at the top along the that metal rail that goes across at the top.
But I want some support at the bottom as well. What can I screw in near the bottom? I know I can't screw into the floor because of the gas tank.
But can I screw into the wheel wells? Maybe screw some screw some small wood blocks onto the wheel behind the partition and then screw the partition to the small wood blocks.
What a lot of members have done, when mounting an amp rack or partition is glue down a piece of MDF using either liquid nails or some other adhesive that is appropriate and then screwing in that piece.
