NEW Interior LED Mod Thread
Old Jan 11, 2009 | 02:15 AM
  #261
nascar57's Avatar
nascar57
I have a 16254177c psb. What would be the difference between a B and a C ?? I have not Idea what this came out of. Model # is 16255791 Came from parts warehouse #23 block 14 row 56 shelf 11 box 22
Old Jan 11, 2009 | 04:39 AM
  #262
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
The "C" was used in HVACs for later Model years, I'm not sure it would work or not goofball!
Old Jan 11, 2009 | 12:43 PM
  #263
Internets_Ninja's Avatar
Internets_Ninja
Originally Posted by tstar
You need a P/N 16254177B power board then... assuming that you had a 10436062 model HVAC in your 01 Z. Is there anyway you can verify the power board part number OR HVAC model number for me????
Tim
The HVAC Model # on the back of the HVAC unit itself is # 09380441
If you tell me how to find the model #'s for the power board and display board I can certainly let you know as soon as I get it back in the mail.
Would any of this matter if I bought a new HVAC unit from gmdirect? Or are the model numbers only important when dealing with replacing the power board or display board separately?
Old Jan 12, 2009 | 03:13 AM
  #264
tstar's Avatar
tstar
the 090380441 was a 2002 model HVAC, it's possible your Vette was made late in the model year and get a new HVAC or it's been replaced already...
No if you're getting a new one all of this is mute, it only matters if you're doing a board swap. Make sure they sell you a M/N 10345293, this is the latest model and superceeds all 00-04 models.
Tim
Old Jan 12, 2009 | 10:04 AM
  #265
c5blkvetteguy's Avatar
c5blkvetteguy
I have a '97 6-speed (aftermarket hu)(single zone hvac) and want to go blue led's everywhere exept traction I want red. The cargo and under dash lights I dont need done, I have gone a different route with those. I have read this thread and more confused than when I started. What do I need? PLEASE HELP!
Old Jan 12, 2009 | 10:39 AM
  #266
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
You'll need
- a LOT of blue type 74 twist lock LEDs: (4 for drivers side door controls, 2 for passenger side door controls, 3 for the DIC buttons,
- a special 8mm blue LED for the illumination dimmer ****
- I reccomend pre-wired 5mm LEDs for the TC panel. If you have selective ride, you'll need 3 of them, if it's just teh TC button, you'll only need 1
- For the HVAC you'll need 14 LEDs total (type 74 twist locks make you life really easy if you take apart the bulb from the base) . I reccomend getting 2 of the 14 red for the heater side of the HVAC controls. or it will look purple on the red arc.
that should do it.
If you're feeling ambitious, you can solder the type 74 wires into place to make sure they dont' come loose...espcially the ones in the dash.
Old Jan 12, 2009 | 05:20 PM
  #267
nascar57's Avatar
nascar57
Radio Flyer pretty much says whats needed. You can save a little money by Making your own door switch leds with bare blue leds and resistors. Its very easy and covered in the thread somewhere.The passenger word on the hvac doesnt get enough coverage with just 1 led.Some boards have provisions for adding a couple there. I use a 3 led strip piggybacked off the led next door.
There are a couple areas in the radio you can also use this method on.
Definitely put blue leds behind the blue temp sweeps.Looks awsome.
Old Jan 13, 2009 | 03:03 AM
  #268
tstar's Avatar
tstar
He has a single zone HVAC guys...
As Radio and nascar stated there's a lot of bulbs to replace if you're converting your whole interior. the very first post in here will give you the amount of LEDs you'll need. If that doesn't help, let us know what options you have ie. Memory, HUD, Selective Ride ect...
One guy posted in the old Thread about converting his single zone HVAC but I can't find it right now...
Tim
Old Jan 13, 2009 | 11:58 PM
  #269
Internets_Ninja
I wonder if I can order the microprocessor from Texas-Instruments and swap it onto my power board.
I have nothing to lose at this point. My new HVAC is on its way and I fried the old PB MP
Old Jan 14, 2009 | 12:53 AM
  #270
tstar's Avatar
tstar
If you don't mind spending the money, sure why not? Of course there's no garantee (however it's spelled, I hate spelling this stupid word!) that it is the processor...
Do you have the equipment to replace an IC? I've never tried replacing one with just an iron and a solder sucker... I suppose it can be done if you're very patient.
Tim
Old Jan 14, 2009 | 11:07 PM
  #271
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I finally took the plunge and converted my rear view mirror to full white LEDs!!
I think it turned out great! Now I need to attack the doors and DIC...
Old Jan 15, 2009 | 01:58 AM
  #272
tstar's Avatar
tstar
Good job!
Did you get all of them to light up? Also any good tricks to cracking the case open??
Tim
Old Jan 15, 2009 | 03:14 AM
  #273
ljthe2nd's Avatar
ljthe2nd
Good job!
Tim
You still haven't tried to open that mirror yet?
Old Jan 15, 2009 | 05:28 AM
  #274
tstar's Avatar
tstar
I'm not opening yours!!!! It's just fine the way it is!
And no I haven't cracked one open yet... When I do I think I'll take a few pics though.
Tim
Old Jan 15, 2009 | 10:38 AM
  #275
mtndv8's Avatar
mtndv8
Default Maika'i Hana!
Looks sweet! Nice work!
I'd love to see pics of the doors and DIC done in white when you're finished...
Aloha,
Michael
Old Jan 15, 2009 | 04:06 PM
  #276
nascar57's Avatar
nascar57
Thanks to Tim, I have one here ready to be cracked and converted.Did you knock down the helper led with a resistor??We all would love to see more pics of it apart and what it looks like in your car!!
Old Jan 15, 2009 | 10:27 PM
  #277
YLO Z06's Avatar
YLO Z06
Good job!
Tim
Yes, I got them all to light up, although the ouside rows do not light up fully due to different resistence levels in the stock wiring (as the stock LEDs had a middle row of blue lights that evidently are different than the outer yellow lights). But you really do not notice once the lights are on -- they are much brighter than stock!
I used the website you gave me a few pages ago as a guide -- www.spdkilz.com -- very helpful tech tip! The LED cover plates are hard to pry off and harder to get back in - take care not to knock the LED circuit board around too much or you will loosen the LED soldering and the lights will go out. I had to re-solder several times. Use alot of solder to prevent this.
I used a very small flathead screwdriver to pry the face surround off the mirror base in several places. It came off fairly easily, actually. Make sure you hold the actual glass mirror in place or it may fall off the backing mount. Getting to the center "helper" light was not too hard; just pull the main circuit board off the mirror backing slightly and use your small flathead to wedge the LED out of its hole. 2 snips of the wires and just insert a new LED into the wire looms and you are done.
To NEW Interior LED Mod Thread
Old Jan 15, 2009 | 10:31 PM
  #278
YLO Z06's Avatar
YLO Z06
I did not put a resistor on the "helper" LED. It is brighter than stock for sure, but it is not distracting at night and puts a cool blue/white glow on the shifter area. I did not take any pics of the mirror while apart, as I was doing this in my garage at night and wanted to finish as fast as possible. There are pics on www.spdkilz.com of the process that I used that were very helpful. I will take some more pics of the interior at night to show you what the effect is.
Old Jan 16, 2009 | 02:10 AM
  #279
tstar's Avatar
tstar
Thanx for all the info!! I'm sure it'll come in handy for futute Modders...
Tim
Old Jan 16, 2009 | 10:35 AM
  #280
Espresso's Avatar
Espresso
Thanks! I will do that this weekend and hopefully be done.
