NEW Interior LED Mod Thread
Old Jan 29, 2009 | 04:49 PM
  #301
jiujitsu's Avatar
jiujitsu
Default LED modules
that kit looks good but i am trying to do this the cheap way. how about these. they draw 80ma. if i powered them off my fog lights do you think they will hurt anything? http://www.oznium.com/led-modules
Old Jan 29, 2009 | 10:41 PM
  #302
nascar57's Avatar
nascar57
I'm not sure if those are long enough to cover the cove area. YOu could order 1 ft. of these.You would have to solder wires where you cut the lengths but its not too hard.
http://www.oznium.com/thin-waterproof-ribbon
These are even a better deal especially if you are doing red. The other colors are more but still not bad.
http://www.superbrightleds.com/cgi-b...i?product=BARS
These you would only have to solder to one strip as they come with wires attached.Cut and solder to the other one unless you order 2.
Are you having fun yet?
Old Jan 30, 2009 | 02:19 AM
  #303
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
If you want to go cheap, make your own lightbar out of 1/2" plexi;
http://www.oznium.com/images/vette/led-install.pdf
I did it this way, although if I had to do it again I'd probably get one of those kits.
You'll be fine with adding only an additional 80mA draw on the Fog circuit...
Tim
Old Jan 30, 2009 | 07:50 AM
  #304
mcgilles's Avatar
mcgilles
I have these in my side vents:
http://www.oznium.com/led-flex-strips
9.5" red strips, one on each side. I built a foundation of 1/4" plexiglass just to elevate it so the lip of the vent doesn't block the light. these allow you to aim the light outwards better.
I'll try to post some pics, my gf has my camera right now though!
Old Jan 30, 2009 | 10:42 AM
  #305
mtndv8's Avatar
mtndv8
I've purchased both the items you linked from Oznium and the oval one is smaller than a half dollar (I'm using 2 of these to light up my license plate) and the linear one is aprox 2.5" long. (in my glove box) You might need a few of them so the cost would probably be the same or more and like they say, you'll have to solder/splice the modules together.
I'm searching for an amber match to my DRLs right now, then they're going to get tstars turn signal mod!!!!
...I know, I know, pictures when done!!
Old Jan 30, 2009 | 12:21 PM
  #306
tstar's Avatar
tstar
Good to see you posting in here again!!
Tim
Old Jan 30, 2009 | 12:22 PM
  #307
tstar's Avatar
tstar
You're going to have to get a trailer to put all your relays in brudda...
Old Jan 30, 2009 | 01:16 PM
  #308
rpm462's Avatar
rpm462
Tim..what are you doing up this time of day?? I thought you were nocturnal!
Old Jan 30, 2009 | 02:22 PM
  #309
mcgilles's Avatar
mcgilles
Tim
thanks That sure is nice to hear. I've been watching and reading this thread, lots of great info. I just haven't had anything to post recently. I've been spending my time hooking up all of those LEDs to my security system...its pretty sweet already, and getting better I'm adding 3 more relays and 2 diodes this weekend.
Old Jan 30, 2009 | 02:46 PM
  #310
tstar's Avatar
tstar
Hey it's winter... I get to go to bed at 5:30 now!
Tim
Old Jan 30, 2009 | 02:47 PM
  #311
tstar's Avatar
tstar
Sounds very interesting!!! Hopefully well documented????
Tim
Old Jan 30, 2009 | 02:48 PM
  #312
tstar's Avatar
tstar
HEY! My stars just changed color!!!!
Old Feb 4, 2009 | 11:37 AM
  #313
mtndv8's Avatar
mtndv8
Testing, testing, one, two, three... is this thing on...?!?
Old Feb 4, 2009 | 11:41 AM
  #314
tstar's Avatar
tstar
YES!
Hey Michael... Do you have the link to the original Interior LED Mod thread?
Tim
Old Feb 4, 2009 | 12:01 PM
  #315
mtndv8's Avatar
mtndv8
YES!
Tim
I wish. It was in my subscription list as reference and I didn't save it anywhere else.
Sorry T.
Old Feb 4, 2009 | 12:03 PM
  #316
tstar's Avatar
tstar
Yeah same here!
ANYBODY have the link to the original Interior LED Mod thread???
Tim
Old Feb 4, 2009 | 12:06 PM
  #317
mtndv8's Avatar
mtndv8
Hey Mike!
I just got a set of these in amber. I'd love to see pics of yours!
To NEW Interior LED Mod Thread
Old Feb 4, 2009 | 05:44 PM
  #318
crAzy's Avatar
crAzy
Ok what i am listing here from the 1st post is exactly what i need for that part right? Also the bulbs that were listed in quantity is right as well?
Please let me know if im right or wrong.. I want to changed everything inside the cabin to blue LEDs, except the engine bay light and rear trunk light. I want those super white. Here is the list. Please correct if wrong..
(Switches (Doors, Fog/Trunk, DIC and Traction/Selective Ride Control)
13* ea. – NEO WEDGE Type B bulbs, 10mm (3/8”) diameter $2.99 ea.
http://autolumination.com/74.htm
*Note: If you are optioned with Selective ride control add one NEO Wedge
Dimmer/HUD
4* ea. - NEO WEDGE Type A, 8mm (5/16") diameter $2.99 ea.
*Note: If you do not have HUD subtract THREE. These are the closest fit but the mounting hole will still need filed out just a tad. Some HUD switch packs supposedly have a total of THREE bulbs.
Footwells and Cargo Area
4 ea. – 194 Matrix Super Star bulbs,. 10mm diameter x 26mm overall $7.99 ea.
http://autolumination.com/194.htm
Map Lights
Non Electrochromatic
2 ea. – 212 Festoon 2 LED bulbs, 10mm wide x 44mm overall length. $9.99 ea.
http://autolumination.com/festoon.htm
Electrochromatic
12 ea. 5mm LEDs
*Note: For 2000s check your Map lights to see if you have the LED array or Festoon bulbs, I believe there may have been a cross over early in 2000.
HVAC (Dual Climate) Controller (Leaving stock Orange LEDs in)
14 ea. - 5mm LED's with XXX* Ohm resistors,
OR
14 ea – NEO WEDGE Type B bulbs, (removed from bases) 10mm (3/8”) diameter $2.99 ea.
Under Hood
1 ea. – Super Star Festoon Dome Bulb: White. 10mm wide x 44mm overall $9.99 ea.
UPDATE: The 1997s take a 212-2 Festoon and the 1998 - 2004s use a Type 561 rigid loop bulb. We think the 44mm should work fine in both. See Post #24 by ljthe2nd
**Note – 470 Ohm = Blue, White, Green, Aqua & Pink
560 Ohm – Red, Orange & Yellow)
Old Feb 4, 2009 | 08:06 PM
  #319
nascar57's Avatar
nascar57
The list looks complete as far as I can tell. Oznium now sells them for $2.49 ea.
http://www.oznium.com/corvette-c5-led
Also autolumination has these 30% brighter neo wedges for $3.49 ea. I would be curious to see if these are actually much brighter.
All the tips and tricks are on the forum if you plan to do it right.
Old Feb 4, 2009 | 08:28 PM
  #320
tstar's Avatar
tstar
I'm curious about the new ones also...
Always buy some extra LEDs and post some pics when you get done!
Tim
