NEW Interior LED Mod Thread
Old Feb 4, 2009 | 08:59 PM
  #321
rpm462's Avatar
rpm462
Originally Posted by tstar
I'm curious about the new ones also...
Always buy some extra LEDs and post some pics when you get done!
Tim
I bought a couple of those new ones for my HUD controller, mostly for the Page button to see if it would brighten it up some, but haven't had a chance to install one yet. Will try to remember to take some pics when I do. Really in no hurry to yank all that out again...just did it a couple weeks ago to fix an intermittant bad connection in the dimmer switch LED.
Old Feb 4, 2009 | 09:06 PM
  #322
mcgilles's Avatar
mcgilles
Sounds very interesting!!! Hopefully well documented????
Tim
sure is, the engineer in me comes out all over the place when I work on my car. I've got full color AutoCAD drawings of all of the stuff I've done to the car. without them I couldn't possibly make sense out of all of the wiring! I've got places full of wires that had almost none stock...must be a sickness!
Old Feb 4, 2009 | 09:08 PM
  #323
mcgilles's Avatar
mcgilles
Originally Posted by mtndv8
Hey Mike!
I just got a set of these in amber. I'd love to see pics of yours!
I thought I just posted these pictures somewhere...maybe that was something different. but here are mine. 9.5" LED strips in Red. the mounting foundation is 1/4" plexiglass, needed it only so the lip around the air vents would not hide the light. I cleaned and double sided taped them to the outside of the vents, running the wires inside was not bad at all, there's plenty of access.
I would like to see what they look like in Amber! pics when you get them installed!
Old Feb 4, 2009 | 09:09 PM
  #324
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Yeah they aren't easiest switches to get out... For the Page button I've been using a 3mm discreet w/resistor and inserting the LED into the hole and bending it so it's aimed right at the back of the button. The stock bulb location is just not in the right location for an LED to light it up correctly...
Tim
Old Feb 4, 2009 | 09:10 PM
  #325
crAzy's Avatar
crAzy
Ok i will deff need help with this. So far i have 28 Blue Type B LED Neowedge and 4 type A neowedges. Is there anything else i need? What bulb is the one that shines down on your hand when driving at night? I think stock is red/orange. Id like that to be blue as well... Also would like the rear view mirror lights hyper white.
Thanks for your help..
Old Feb 4, 2009 | 09:11 PM
  #326
tstar's Avatar
tstar
I figued as much, all of your DIY posts are just excellent!
Tim
Old Feb 4, 2009 | 09:32 PM
  #327
tstar's Avatar
tstar
194s for your footwell and cargo lights... Now please keep in mind that you're doing a very basic swap and the easist way to do it. The NEOs will give satisfactory results in most areas with some spottng, the problem areas have been addressed in the first page or two.
Several of us hosting this Thread did custom LED installs to make the lighting perfect so I don't want you to be mislead with the results you see in some of the pics in here compared to what you might get with the NEO install. The best thing to do is bench test your modded component to see if it is satifsfactory before continuing on to the next one... If you aren't happy with the result, post up and we'll guide you through some solutions.
Just an example, but this is a custom job that took some time and trial and error to get the light levels even across all the components;
But look at the "Door Locks" on the Driver's Door switch, it's still a bit dark in the pic. Although it's hardly noticable to the eye, I'm annal and use the digital camera to show flaws in the lighting... Anyway, I just don't want you to be mislead by some of the pics in here...
The "Helper" LED in the mirror is an Orange 5mm LED, IF (big if) you can crack your mirror case open without marring it, you can replace it pretty easily... EDIT: Matter of fact I have an extra Mirror laying around, I'll see if I can crack it open for you and get some pics...
Tim
Old Feb 4, 2009 | 09:35 PM
  #328
tstar's Avatar
tstar
Nice... I have screens over my Gills and I got a Spiderman comic book cover!
Cute huh?
Tim
Old Feb 4, 2009 | 10:45 PM
  #329
SilverC54me's Avatar
SilverC54me
Yeah same here!
ANYBODY have the link to the original Interior LED Mod thread???
Tim
Tim
I think I have one in my email notifications for that thread. I will look when I get home and post.
Gary
EDIT: It looks like the original thread is still locked.
Old Feb 5, 2009 | 12:41 AM
  #330
tstar's Avatar
tstar
Originally Posted by SilverC54me
Tim
Gary
Thanx Gary!!! Got your Email and forwarded the link to the powers that be...
Tim
Old Feb 5, 2009 | 01:43 AM
  #331
mtndv8's Avatar
mtndv8
...I would like to see what they look like in Amber! pics when you get them installed!
Thanks Mike!
No problem. I'll post pic when done.
Old Feb 18, 2009 | 10:08 PM
  #332
jiujitsu's Avatar
jiujitsu
Default HVAC lights wont turn off
i installed blue leds in my hvac and it looks good but now they wont turn off. i can lock my door and come back the next morning and they are still on. what the hell did i do wrong? will this run down my battery?
Old Feb 18, 2009 | 10:15 PM
  #333
rpm462's Avatar
rpm462
Is anything else on? Not to state the obvious but are you sure your dimmer switch isn't turned on? Done that before myself.
Old Feb 19, 2009 | 01:12 AM
  #334
tstar's Avatar
tstar
Well the good news is they draw very little current. The bad news is this happened to me once ad I couldn't understand why but I didn't have the car here to work on it. It was a 98, your profile isn't filled out... what year is your Vette?
We can run some experiments if you'd like to try and resolve it. The same thing happens to the C6 courtesy lights when swapped to LEDs, I was suspeting that the lights weren't drawing enough current to let the BCM know they were on. Maybe adding a small resistor the the wire on pin 16 would help or a newer model HVAC...
Tim
Old Feb 19, 2009 | 01:39 AM
  #335
dh305's Avatar
dh305
Tim, thanks for doing this. I am considering doing my car in blue (car is navy blue metallic). I have followed your threads forever. You are **** and I love it. I will be contacting you. AGAIN, THANKS FOR YOUR TIME.
Old Feb 19, 2009 | 01:44 AM
  #336
tstar's Avatar
tstar
Beautiful Vette!!! The Blue interior lighting is going to look great in it!!
BTW Did you just call me an ***?
Tim
Old Feb 19, 2009 | 05:08 AM
  #337
Espresso's Avatar
Espresso
The results speak for themselves on this one!
To NEW Interior LED Mod Thread
Old Feb 19, 2009 | 10:01 AM
  #338
crAzy's Avatar
crAzy
Hmm thats strange. I have done all of mine doors, hud, dic, hvac, rear trunk button, rear view mirror and TC. They usually stay on for a bit after i turn the car off but they do go off. Have you tried turning the headlights on then back off?
I dont know what you could of done. You pulled the hvac out, unsoldered the bulbs and replaced them right? Did you put resistors in them? I never did.....
Old Feb 19, 2009 | 12:38 PM
  #339
tstar's Avatar
tstar
we're discusing it off line... I suspect the power board got fried by a shorted LED/resistor. That's the only thing I know that will cause this...
ALWAYS OHM out your lighting circuit after installing LEDs in the HVAC or RADIO to make sure there are no shorts between the positive and negative leads, then power them up with a 9 volt battery to verify all the lights work. THEN put it together and plug it in...
Tim
Old Feb 22, 2009 | 10:03 PM
  #340
Superman09's Avatar
0Superman09
Former Vendor
I have a few questions here....
Do the NEO Wedge leds still require resistors or are they plug n play?
For the HVAC swap, can you simply swap out the bulbs for the NEO Wedges and call it a day or do you still need resistors and what not? What is OHM out the lighting circuit?
Thanks!
