NEW Interior LED Mod Thread
Old Feb 28, 2009 | 09:44 PM
  #361
Superman09's Avatar
0Superman09
Former Vendor
On the Neo wedges, is the thinker wire the positive and the thin wire the negative?
I am having some issues with 2 of the 4 spots on my HUD/dimmer. The LEDs are working when tested but can't get them to light up once installed, same with my truck release ?
Old Feb 28, 2009 | 10:37 PM
  #362
nascar57's Avatar
nascar57
I havent notice a difference in the thickness of the + and - wires. If you look at them close[magnifing glass] the positive side has the miniature resistor on that leg. Or you can use a 9 volt battery to test them and find out which leg is the positive etc. Dont worry about hooking them up backwards, it wont hurt them they just wont light. If they dont work when you install them, try turning them 180 degrees then they should light.
Another way to tell the + side is if you look closely at the clear part of the led the + side will be the fatter side, the - side is very skinny. Pm me if you have any further questions.
Old Mar 1, 2009 | 01:44 PM
  #363
Superman09's Avatar
0Superman09
Former Vendor
well i messed up my HVAC trying to led mod it. I had the bottom LEDs done and was moving up. After each LED i did i would test it to make sure it was working. Went to test this one and all the lights went out and a little smoke puffed out. Must have been crossed or something. I am not a good solderer and probably shouldnt have tried this Any advice on maybe how i can fix it or what happened? Thanks!
Old Mar 1, 2009 | 04:04 PM
  #364
Superman09's Avatar
0Superman09
Former Vendor
if i plug it into the car.... nothing. If i apply power to one of the LEDs, they all light up perfect.....
Old Mar 1, 2009 | 04:06 PM
  #365
Esp0's Avatar
Esp0
Okay, what about those who dont have steady hands and never soldered something before BUT still want to replace every LED inside my c5?
Old Mar 1, 2009 | 04:11 PM
  #366
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Sounds like you fried your power board... You didn't follow my directions did ya?
Tim
Old Mar 1, 2009 | 04:14 PM
  #367
tstar's Avatar
tstar
JW Motoring offers LED Mod services... contact Jhonathan_W
Tim
Old Mar 1, 2009 | 04:16 PM
  #368
Superman09's Avatar
0Superman09
Former Vendor
i didnt find any instructions other than a diagram for the bulbs. Whoops! Any way to check this for sure or fix it?
Old Mar 1, 2009 | 04:22 PM
  #369
tstar's Avatar
tstar
Sorry, it's right above your first post in here, I thought you saw it;
"ALWAYS OHM out your lighting circuit after installing LEDs in the HVAC or RADIO to make sure there are no shorts between the positive and negative leads, then power them up with a 9 volt battery to verify all the lights work. THEN put it together and plug it in..."
In all honesty, I would say it's toast. I wish I had the schematics for these boards... Your best bet is to score an inexspensive one off Ebay or possibly a Vette salvage yard.
Tim
Old Mar 1, 2009 | 04:41 PM
  #370
Superman09's Avatar
0Superman09
Former Vendor
Fail!
Old Mar 1, 2009 | 04:54 PM
  #371
tstar's Avatar
tstar
What year is your Vette I can check to see if I have any spare power boards left, kinda doubt it though...
Tim
Old Mar 1, 2009 | 04:55 PM
  #372
c5blkvetteguy's Avatar
c5blkvetteguy
I have to give you credit for trying to do it yourself. I was going to do mine, but thought better of it. Even with my many years of soldering smt parts, I felt better with someone else doing the job.
Old Mar 1, 2009 | 04:59 PM
  #373
tstar's Avatar
tstar
You're too busy building cool stuff for your Vette to be bothered with LEDs anyway!
Tim
Old Mar 1, 2009 | 05:05 PM
  #374
Superman09's Avatar
0Superman09
Former Vendor
lol, i suck at soldering but figured i'd try to save myself some money and do it myself, now i've dug a deeper hole, lol.
it is a '99. You are JW's LED tech right? If so i already contacted him about one. I know he had some cores available, not sure if he does anymore. LMK what you can do to help. if you'd rather take it to PMs that works also, thanks! I really appreciate it
Old Mar 1, 2009 | 05:12 PM
  #375
c5blkvetteguy
Thx tstar You are led guru
Old Mar 1, 2009 | 05:29 PM
  #376
tstar's Avatar
tstar
I do have a board here that I just repaired for you (a track had fried and was an easy fix) I can't guarentee that it'll work perfect but it powered up another unit fine. It's possible that the lights may stay on after you turn the car off... I can't test for that here.
PM me if you wanna give it a shot, at least it'll keep you warm till you find a suitable replacement.
Tim
Old Mar 1, 2009 | 06:00 PM
  #377
Superman09's Avatar
0Superman09
Former Vendor
PM sent! You the man!
To NEW Interior LED Mod Thread
Old Mar 17, 2009 | 08:37 PM
  #378
mtndv8's Avatar
mtndv8
Aloha T,
Did we ever get the original LED Mod Thread back??
Just curious...
Mahalo,
Michael
Old Mar 17, 2009 | 10:02 PM
  #379
mcgilles's Avatar
mcgilles
Originally Posted by mtndv8
Aloha T,
Just curious...
Mahalo,
Michael
no sign of it yet, we need to find that one there was alot of great stuff in it also.
Old Mar 18, 2009 | 12:41 AM
  #380
tstar's Avatar
tstar
Aloha T,
Just curious...
Mahalo,
Michael
Yes there was and No I can't find a link for the original, if anyone has it PLEASE send it to me so I can get it reactivated for us....
Tim
