NEW Interior LED Mod Thread
Old Nov 9, 2010 | 04:45 AM
  #561
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Please PLEASE do NOT power up the HVAC before you check for shorts!!!!!!!!!!
This warning goes unheeded time and again....
Tim
Old Nov 9, 2010 | 05:18 PM
  #562
VJD2's Avatar
VJD2
St. Jude Donor '11
I've read so much in this thread, refresh my memory on how to check that? Wrap the resistors in some electrical tape comes to mind. Make sure the solder is not connecting to circuits is another I remember.
Old Nov 9, 2010 | 08:38 PM
  #563
nascar57's Avatar
nascar57
I take my fluke meter and make sure there is no continuity between the positive and negative leads on the leds.
Old Nov 10, 2010 | 02:37 PM
  #564
tstar's Avatar
tstar
The resistors get very hot, I wouldn't use anything that could melt/burn. I just keep seperation from the leads and have zero issues. As Tom said, Ohm em with an Ohm Meter to make sure the positive and negative leads are not connected together somewhere!
Here's what I do right after soldering... Ohm out a few of the positive and negative leads, then use a 9 volt battery across one of the LEDs to make sure all of the LEDs are good. Then I'll connect everything up and hook up a 12 volt power supply to the back of the HVAC and leave it "on" for about 4 hours to make sure none of the LEDs will "cook off" and go bad...
Tim
Old Nov 13, 2010 | 09:30 PM
  #565
rpm462's Avatar
rpm462
Well, my son and I got sort of motivated and a little imaginative with some LED strips this weekend and spliced them into the remote cove light setup I got from JW Motoring a while back. This should be pretty neat for shows, parades and cruise-ins since the setup has different flash and steady modes, obviously not going to use them on a daily basis.
Pics
Some other LED's we had spliced in a while back.
Old Nov 14, 2010 | 04:26 AM
  #566
tstar's Avatar
tstar
Wow!!!!! You're ready for a parade now!
Tim
Old Nov 14, 2010 | 11:48 AM
  #567
nascar57's Avatar
nascar57
Looks good man! Looks like the leds are on the inside of the headlights.
Old Nov 20, 2010 | 08:47 AM
  #568
darkstang5887's Avatar
darkstang5887
Hey guys I am in need of some help. I decided to do the interior in blue LEDs and I have one problem
How do u get the trunk/fog light switch brighter? I used a neo wedge and it's very dim compared to the others.
Also are type a wedges brighter than type b based on size alone??
Please help!!!
Old Nov 20, 2010 | 02:38 PM
  #569
tstar's Avatar
tstar
Yeah the Trunk/Fog and Traction Control button need some "help"... I've had good success using a superbright LED in a stock holder or dropping a 3mm down into the switch soldered directly unto the pads (with a resistor of course).
I've seen no brightness level differences between the two sizes...
Tim
Old Nov 22, 2010 | 01:11 PM
  #570
darkstang5887
thanks alot tstar you really are the LED god
Old Nov 22, 2010 | 11:34 PM
  #571
VJD2's Avatar
VJD2
St. Jude Donor '11
One other question.
What do you do about the fit with the new resistors and the rubber mat/overlay on the HVAC. Obviously it doesn't fit great now that the extra resistors are there.
Thanks again.
EDIT: Well I got it together and the "AUTO", "MODE" and "REAR" buttons are a bitch to press down I'm guessing due to the resistors. I'm guess you just have to adjust the resistors and possibly cut the rubber overlay to flatten it out some to free up the buttons?
I'll play with it tomorrow but I'm super happy with the way it came out. Red's are a little dull but I'm ok with that. It looks sick! On to the radio!
Old Nov 23, 2010 | 05:52 AM
  #572
tstar's Avatar
tstar
I cut portions (or all) of the "collar" out to accomodate the Resistors then lay the rubber mat down before you insert the LED/resistors... That way they lay on top of the mat.
Pics are a requirement ya know!
Tim
  #573
tstar's Avatar
tstar
Thanx for the kind word but that is FAR from the truth!
Old Nov 23, 2010 | 02:35 PM
  #574
VJD2's Avatar
VJD2
St. Jude Donor '11
Tim
Cool thanks for the tip, that makes sense!
Oh for sure, I'll post up some pics. Snapped a few last night when I hooked it up to a 9V but I'll get more when I reinstall it.
Old Nov 28, 2010 | 09:59 PM
  #575
VJD2's Avatar
VJD2
St. Jude Donor '11
Default Final Product!!
Well its finished and installed. Can't believe I got it done and it works and looks great!! The pics make it look much brighter than it is and shows some hot spots but it looks even in person. Now onto the radio!
Old Nov 28, 2010 | 11:33 PM
  #576
corvettedaddy11's Avatar
corvettedaddy11
Wish mine was done tim!
Old Nov 29, 2010 | 03:03 AM
  #577
tstar's Avatar
tstar
Nice work!!!!!!!!!!
Tim
To NEW Interior LED Mod Thread
Old Nov 29, 2010 | 03:05 AM
  #578
tstar's Avatar
tstar
Sometimes you have to wait for the impossible to happen! Besides, I ate too much Turkey and I can't move...
Tim
Old Nov 29, 2010 | 09:16 AM
  #579
corvettedaddy11
Old Nov 30, 2010 | 08:02 AM
  #580
darkstang5887
how hard is it to really do the hvac unit? i have some soldering exp.
