NEW Interior LED Mod Thread
Old Nov 6, 2010 | 08:09 AM
  #541
ASarsano's Avatar
ASarsano
any one ever done an led swap into the instrument cluster?
Old Nov 6, 2010 | 11:13 AM
  #542
tracer1's Avatar
tracer1
Default LED Mod
Hi Tim....did you use resistors with all your bulbs. In some pics it looked as it had no resistors for some (unless I missed it). Also, would the 5mm pre-wired bulbs work instead of the neo?
Old Nov 6, 2010 | 01:45 PM
  #543
tracer1's Avatar
tracer1
Nevermind the dumb question on the pre-wire....resistors won't fit thru the hole, duh.
One other question....when I pulled my radio out, I noticed 3 loose wires taped together. Red, Green, Black. Have any idea what these are and what they are for?
Thanks,
Gregg
Old Nov 6, 2010 | 01:52 PM
  #544
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You mean for the warning lights?? Not that I'm aware of...
The gauges themselves are lit from the front by UV tubes...
Tim
Old Nov 6, 2010 | 01:54 PM
  #545
tstar's Avatar
tstar
Thanks,
Gregg
I don't use the bulb holders at all, I solder directly unto the pads on the PCB boards so I can vary the depth and angle for the best effect.
No idea on the loose wires behind the Radio, sounds like an aftermarket mod to me...
Tim
Old Nov 6, 2010 | 02:12 PM
  #546
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Can you direct me to the led strip mod you did in the armrest thingy Tim? If it's in this looooooooong thread I missed it.
Old Nov 6, 2010 | 02:18 PM
  #547
tstar's Avatar
tstar
Seperate Thread my friend.... Let me find it!
http://forums.corvetteforum.com/c5-g...-be-light.html
PM me if you need anymore info...
Tim
Old Nov 6, 2010 | 02:20 PM
  #548
JW Motorsports
Banned Scam/Spammer
Roger that. We have a convo going in 2 threads and email lol
Old Nov 6, 2010 | 02:23 PM
  #549
tstar's Avatar
tstar
I know.... we're some dynamic somes-a-bitches aren't we?
Or we have ADD...
Old Nov 6, 2010 | 05:27 PM
  #550
tracer1's Avatar
tracer1
Tim
Don't know about the aftermarket....car is totally stock. wires are from the main radio harness (black plug).
anyway thanks,
Gregg
  #551
tracer1's Avatar
tracer1
Or we have ADD...
or both........
Old Nov 6, 2010 | 07:29 PM
  #552
tstar's Avatar
tstar
or both........
That's us... Dynamic ADD Bitches!
Hey, PM C5Bearsfan about those wires...
Old Nov 6, 2010 | 07:40 PM
  #553
SilverC54me's Avatar
SilverC54me
anyway thanks,
Gregg
Are the wires coming out of the radio or the wire harness pluged into the radio?
Gary
Old Nov 6, 2010 | 10:26 PM
  #554
tracer1's Avatar
tracer1
Gary
If I remember correctly, they're coming out of the harness from the radio. Although everything on the car works perfectly as it has for 10 years. It has the 12 disc in the trunk which works great, all speakers work, all controls on radio work. Only thing not working are the radio lights. The panel for the time & features works & lights fine. That's the reason I took the radio out to maybe mod the stock lights to LEDs. Other than the radio lights, everything inside and outside of the car work perfectly, that's why I couldn't understand why they were there & not hooked up.
Thought maybe tim or someone would know with all the modding going on.
Any help would be great.
Gregg
Old Nov 7, 2010 | 01:41 AM
  #555
SilverC54me
Gregg
Those three wire sound like something aftermarket was installed at one time. The only group of wires that I know that are taped up like that is in the passenger foot well next to the fuse block. These are Orange, Black and Yellow if I remember correctly.
Gary
Old Nov 7, 2010 | 07:20 AM
  #556
tracer1's Avatar
tracer1
Thanks for the info, Gary. Haven't checked the footwell. Will later today. If I find out what they were for, will let you know. In the meantime, "if it ain't broke, don't fix it".....unless you're a modder!!!
Gregg
Old Nov 8, 2010 | 06:53 PM
  #557
VJD2's Avatar
VJD2
St. Jude Donor '11
Ok, few more questions while I wait for my stuff to come in.
I noticed I ordered 470k resistors. Is there any difference between 470 and 470k? I noticed there were two listings on the site. Both 1/4 watt.
I also forgot to order the resistors for the red LED's. I don't feel like ordering and waiting for those to come in but I can't find any where local that carries the 560 1/4 watt resistors. I can only find 1/2 watt ones at Radio Shack. Can those be used or is that a no no?
Thanks again.
To NEW Interior LED Mod Thread
Old Nov 8, 2010 | 10:53 PM
  #558
SilverC54me
Answers to your questions are in RED.
Gary
I noticed I ordered 470k resistors. Is there any difference between 470 and 470k? I noticed there were two listings on the site. Both 1/4 watt. A 470K resistor is has 1000 times more resistance than a 470. The 470K ones will not work for you.
I also forgot to order the resistors for the red LED's. I don't feel like ordering and waiting for those to come in but I can't find any where local that carries the 560 1/4 watt resistors. I can only find 1/2 watt ones at Radio Shack. Can those be used or is that a no no? A 1/2 watt resistor can dissipate 2 times the heat a 1/4 watt can. You can use the 1/2 watt resistors in place of 1/4 watt. However, some locations do not have enough room for the larger 1/2 watt resistors.
Thanks again.
Old Nov 8, 2010 | 11:47 PM
  #559
VJD2's Avatar
VJD2
St. Jude Donor '11
Thanks Gary.
Yup, that is what I thought. I can't win with this project but damn it I'm learning a lot! Trial and error.
Thanks for the advice on the 1/2 watt resistor. Seeing as I have to reorder all the 470 resistors I might as well order the 1/4 560's.
What would I do without you guys?!:o
Old Nov 9, 2010 | 12:16 AM
  #560
SilverC54me
No problem. If you have any more questions, just post.
Gary
