ACI front splitter question
Old Apr 15, 2008 | 09:09 PM
jeffsc5's Avatar
jeffsc5
Default ACI front splitter question
Hi guys,
OK, I have the Caravaggio rear wing and ACI front splitter in hand. MCM hood will be here any day. Can't wait!! Will post pics as soon as I get her back from the shop. OK, dumb question, I placed the front spoiler under there to see what it looks like and the 3 moldings are in the way (mine were moved forward because of my S/C setup unfortunately). Am I assuming these are totaly removed? Anyone who has this, please chime in so I can pass the info on to the paint guy just in case he isn't sure. Thanks guys!
Jeff
Old Apr 15, 2008 | 09:23 PM
stormrider's Avatar
stormrider
If you are referring to the three black air dams, you remove all three to install the splitter and then reattach the center one. The center air dam directs air into your radiator without it you will run hot.
Old Apr 15, 2008 | 09:29 PM
jeffsc5's Avatar
jeffsc5
Don't suppose there are directions somewhere out there as to the placement of the center air dam? And the 2 side ones are removed entirely as well? I know these are questions that are going to come up and I would just assume have everything ready for him when the time comes. Thanks for the help.
Old Apr 15, 2008 | 09:36 PM
batsallover's Avatar
batsallover
Can't wait for the pics. And leave the center air dam for cooling.
Old Apr 16, 2008 | 10:14 AM
kww's Avatar
kww
I just removed the side dams that were in the way-removed the center dam and then put the center back on in the same holes. You'll want that center dam for air flow and also as a nice little warning that your about to scrape up the splitter if your not careful.
Old Apr 16, 2008 | 10:23 AM
stormrider's Avatar
stormrider
If you didn't receive instructions with the splitter call ACI and they can email them to you.
Old Apr 16, 2008 | 12:32 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
That's the way it's done..
Old Apr 16, 2008 | 01:18 PM
ZO-SICK's Avatar
ZO-SICK
You should have the hood this week...
Old Apr 16, 2008 | 05:04 PM
WickedQuik's Avatar
WickedQuik
Found this out when my installer removed all 3 factory pieces and the car began to run hot all the time. Went to talk to my friendly GM Corvette mechanic and he said "Some idiot removed your center air dam when they installed your ACI chin spoiler. You need that to direct air into your radiator" So another $59 and whallla --- back to factory temperatures. We all have to learn the hard way I guess. Im guessing the installer either didnt read or didnt get to read the installation instructions.
Old May 5, 2008 | 06:43 PM
XLR8BYU's Avatar
XLR8BYU
how difficult is this install? I just got mine this week and was going to do it myself, but the directions are hard to understand the pics are blacked out. Anyone document there install?
Old May 6, 2008 | 09:35 PM
WickedQuik's Avatar
WickedQuik
Didnt document mine, but the installer said it was pretty simple. You will need someone to help you hold the spoiler in place to mark the spots where the holes will need to be drilled. I think a total of 13. After that its drill, place screw tab in place, replace spoiler in position, and run the screws through. I have had mine on and off by myself on several occasions. Good luck.
Old May 6, 2008 | 11:48 PM
spiral04's Avatar
spiral04
What about the pop rivets? I have mine in hand ready to install, but I didn't have a rivet gun. Did you only use the screws in the tracks??
Old May 7, 2008 | 06:53 AM
Glennm27's Avatar
Glennm27
You MUST rivet the brackets to the inside of the facia.
The entire install is straight forward and easy. I've done a few of them....
Old May 7, 2008 | 07:05 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
Installed my ACI and retained all three air dams
Old May 7, 2008 | 08:59 PM
71corv's Avatar
71corv
St. Jude Donor '08
I have also re-installed the front air dams after installing the ACI.
Gene
To ACI front splitter question
