98 vert has E.D. hatch lid problem
Old Apr 18, 2008 | 08:09 PM
Nashville Natureboy's Avatar
Nashville Natureboy
Default 98 vert has E.D. hatch lid problem
My 98 convertible's hatch lid where top folds down suddenly has a problem staying up. It is very weak in up right position. A slight wind or even parked with front lower than rear makes it fall. Anything I can do to correct this problem. It has already cause some embarrassing moments, if you know what I mean.
Old Apr 18, 2008 | 10:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
give it some cialis!
Old Apr 18, 2008 | 10:27 PM
MagRedConv's Avatar
MagRedConv
I've never encountered that issue with my vert. Check the mechanism that "keeps it up", I'm sure that it just a worn out detail or perhaps the entire assembly.
Old Apr 19, 2008 | 01:17 AM
DeeGee's Avatar
DeeGee
Thats not a common problem
Looking at the Shop Manual there are hinges either side of the tonneau and a strut which is mounted centrally. I assume your strut is giving up the ghost. The replacement is very straight forward if that's the problem. Unbolt the strut at both ends and fit a new one.
If you decide to replace it I can send some pics.
Old Apr 19, 2008 | 01:44 AM
BATM4N's Avatar
BATM4N
Any way you can take some pics and post so we can see exactly what were dealing with?
Old Apr 19, 2008 | 01:57 AM
DeeGee's Avatar
DeeGee
Here's a pic that shows the hinge and the strut
You get at the front nut from the tonneau compartment and the rear nut from the trunk.
Old Apr 19, 2008 | 09:28 AM
Nashville Natureboy
Thanks DeeGee. That was most helpful.
Old Apr 19, 2008 | 09:44 AM
steve8's Avatar
steve8
Things could be a lot worse.
To 98 vert has E.D. hatch lid problem
