91 is the recommended octane level. You can use 87 if nothing else is available but your PCM will pull timing in order to keep the engine from knocking (not good). Use 91 or higher for best performance
Engine will still knock. The PCM will adjust when it hears knock, but it will keep attempting to return to normal, thus always getting some knock.
I don't know about you, but I'd pretty much want to avoid *ANY* knock if I could. And you can for $.20-.25/gallon or only 5-6% more $ than 87 octane.
In case you don't know... knock is detonation. Detonation occurs from fuel spontaneously combusting under heat & pressure over time because it can no longer resist the temptation to ignite. Octane is the measurement of a fuels ability to resist combustion. Higher is better.
The knock you "hear" is the random flamefront colliding with the flamefront from your spark. Any detonating could cause craters in your pistons.
But seriously though... you COULD use 87... but it's not really doing the car any favors, and as was said above, you do get denotation, although briefly. You need to have it happen before the PCM can detect it and apply the correction.
I'd only buy it as a last resort, like as in, the station sold out of premium and you don't have enough gas to run up the road to the next station. Then I'd buy just enough to get to the next station.
It costs about $3 per tank to fill 'er up with premium over regular... Why even consider it?
This is true! The only time you could probably get away with running 87 octane would be in the extremely cold winter time, but even then it would probably still pull out a lot of timing. In the hot summer, especially when you're stuck in traffic with the AC going and your oil and coolant temps are up, you'll get pinging like crazy with 87, the computer won't be able to pull out enough timing.
Let's put this another way, my car when it still had the factory stock tuning would get a couple of degrees of knock retard in the higher gears on a hot day at full throttle even with 94 octane!!
Don't risk it, put nothing but premium in these cars.
Great thread of advise. I would never consider putting something less in the vette unless absolutely had to - then just a 1/4 tank to get me to the next station. Great advise to show to the wife so she knows I am not just being ****.
