tire pressure sensor (no reading)
Old Apr 21, 2008 | 10:27 PM
tom55's Avatar
tom55
3rd Gear
Default tire pressure sensor (no reading)
I have a 98 vette, all the tires reding show except the left front which shows (l/f tire blank), no reading is this the tire pressure sensor or something else?
Old Apr 21, 2008 | 10:32 PM
Bill Vett's Avatar
Bill Vett
You could try to re-program it again ..but.. You are at the end of the life span for your gen 1 sensors. If on has gone south the others may not be far behind. The Generation 1 ( 97 to 00) sensors are around $85.'s each.
Old Apr 21, 2008 | 10:34 PM
GrayC5's Avatar
GrayC5
You might try resetting the Tire Pressure Sensors (See below.) However, if it is the original sensor, the battery in it is most likely nearing the end of its life cycle and you may need to replace the sensor.
Resetting Tire Pressure Monitors
Good luck!
Old Apr 21, 2008 | 10:35 PM
c5streak's Avatar
c5streak
Probably the sensor battery died. Are they the original '98 sensors? If so, then you probably have a low battery. You can try reprogramming them also.
https://www.corvetteforum.com/techti...D=77&TopicID=1
^----- guess I can't type fast enough
Old Apr 21, 2008 | 10:37 PM
moserbe's Avatar
moserbe
I just replaced all 4 sensors on my 98. I bought them from Gene Culley.
Old Apr 21, 2008 | 10:52 PM
Probably time to get new ones.
To tire pressure sensor (no reading)
