Mouse Repellant
Old Apr 21, 2008 | 10:31 PM
jak565's Avatar
jak565
Default Mouse Repellant
What can you use to keep mice out of your engine compartment? My DD is parked outside nightly on a acreage. Last night a mouse at off all the wires to my headlight, park lights, blinkers....
Old Apr 21, 2008 | 10:37 PM
MagRedConv's Avatar
MagRedConv
This is an odd one. I'm sure someone here will have the answer but in the meantime I suggest keeping a cat under your hood at night.
Old Apr 21, 2008 | 10:45 PM
futuretech's Avatar
futuretech
Leash a puddy tat under your hood. I could loan you my kitty! Sorry, couldn't help myself. Is there a spray repellant for mice?
Old Apr 21, 2008 | 10:47 PM
Crabr1's Avatar
Crabr1
Bounce fabric softner.It works
Old Apr 21, 2008 | 10:55 PM
Gideon's_Test's Avatar
Gideon's_Test
I used moth ***** when mine was stored this winter. I put the moth ***** in an old tube sock...I made several and placed them in various locations throughout the engine compartment...
Old Apr 21, 2008 | 11:01 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Has worked every year I have stored mine. I don't go as far as putting them in my engine bay. Just around the interior and exterior of my garage. and underneath the car. Good luck!
Old Apr 21, 2008 | 11:14 PM
c5mancan's Avatar
c5mancan
Cruising
Oil of Pepermint
Old Apr 22, 2008 | 12:19 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
get a cat
Old Apr 22, 2008 | 12:30 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
For folks with a garage I suggest (I use 'em and they work for me) the sonic electronic pest deterrents that you plug into any house receptacle. They work on pests other than rodents as well. Lowe's/Home Depot @ $15 for two.
Old Apr 22, 2008 | 01:53 AM
DeeGee's Avatar
DeeGee
Old Apr 22, 2008 | 02:42 AM
dieseldave56's Avatar
dieseldave56
Mice don't like the light, so prop the hood open ( assuming you have portable carport or something to cover your car) put drop light under the hood. My folks used to place little Decon boxes under the hood and around the tires. Their problem went away.
I , myself don't have that problem with mice here at 4200 ft elevation. But we do have squirrels that will eat wiring insulation if given the chance, but the bobcats , puma, eagles and sometimes falcons keep the population at bay
Old Apr 22, 2008 | 06:04 AM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I agree. We have 3 dogs in the family so obviously I have dog food stored in the garage. Even in a plastic container mice were attracted. I bought the electronic pest deterrents and no more problems.
Old Apr 22, 2008 | 07:16 AM
kww's Avatar
kww
Old Apr 22, 2008 | 09:57 AM
jovette's Avatar
jovette
Irish spring bars of soap cut into quarters and placed around the car also will work. Perhaps you need to go with some sort of spray you'd apply to the ground around the area where you park. Might want to check with your local nursery / lawn & garden supplier to see what they have to keep rodents away.
Old Apr 22, 2008 | 11:46 AM
bigcypress's Avatar
bigcypress
fabric softener sheets that go in dryer .
To Mouse Repellant
