I'm considering buying a set of these for our '04. Anyone else using them? How are they attached? Is the "built in" jack puck all that useful?
Any comments would be appreciated before I spend $270. + for a set.
Thanks.
Glen
You don't need the built in jacking pucks. The point behind the jacking pucks is to give you a spot lower than the actual body panel so you don't put pressure on the body. This will sit lower than the body panel, so you can just use the bar itself.
OMG What a RIPOFF!! Those are effectively the exact same thing as the $60 ones I linked above. I've seen "Corvette Tax" before, but those take the cake.
I got my rocker rails from A&A Corvette. Elite Engineering do a nice set and CCA sell them. All are Forum Vendors and have a link down the side of C5 General.
