[Z06] problems going into reverse?
Old Apr 23, 2008 | 07:27 PM
Over-torque's Avatar
Over-torque
Default problems going into reverse?
ive seen so many posts by people who have problems getting into reverse. heres a tip that works hot or cold:
if you try to push the selector into reverse (man trans) and it wont go easily, dont try to force it. you could bend the forks. instead, push it up into a forward gear and ease out on the clutch. once the engine starts to bog (and the car wants to go forward), clutch in and the selector should easily go into reverse. then, proceed like you originally wanted to.
im not sure if corvettes are the same, but on most standard transmissions, the reverse gears are not synchronized. all of the forward gears are. so, by going into one of those gears, you are spinning all the gears up and making it easier for reverse to engage.
Old Apr 23, 2008 | 07:38 PM
froggy47's Avatar
froggy47
I do this always, just to baby the rev gear a bit. Always works.
Old Apr 24, 2008 | 01:01 AM
danman_s's Avatar
danman_s
What would be an indication that the forks ended up getting bent? Is it more common on certain model years?
I have a ton of trouble getting the car into reverse when it's cold and am starting to draw up a list of potential parts needed for repair. And get rid of that damn hurst shifter.
Old Apr 24, 2008 | 06:22 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
On my 03-Z, once in a while it's hard to get into reverse I just but it into 5th and then it goes right in..
Old Apr 24, 2008 | 09:46 PM
Over-torque
well, to bend the forks you probably would have to put your weight behind a pull into reverse with the forks misaligned. ie, you probably wont do it by accident.
an indication of bent forks is that kind of effort required to get into reverse regardless of tips/tricks.
Old Apr 24, 2008 | 09:59 PM
Dennis Wilson's Avatar
Dennis Wilson
Same here.
Old Apr 24, 2008 | 10:27 PM
FasterIsBetter's Avatar
FasterIsBetter
On mine, I would drop it into 4th, ease the clutch just a bit, and then up into reverse and it would go right in.
Old Apr 25, 2008 | 12:13 AM
RonVette2's Avatar
RonVette2
With most all my vehicles I have owned that were standard transmissons I always out of habit shift into first, let clutch out a bit till start to pull, step clutch and brake, and go from first to reverse, no issue(s) and nice and smooth
To problems going into reverse?
