NEED HELP !!! oil pressure
Old Apr 24, 2008 | 08:43 PM
zx-12r's Avatar
zx-12r
Default NEED HELP !!! oil pressure
Thanks in advance for your help.
I replaced my oil sensor a few months ago and it lasted about a month then my sensor was pegged again. I have not changed it out again yet but the other day my sensor started going from pegged to zero and back to pegged again. It is getting worse. I have check the oil level and it is fine. When it starts going down if I let off the gas it goes stops and goes back to pegged or sometimes it bounces back and forth.
Has anyone had this happen to them? I am not sure if it is the oil sensor or do I have a bigger problem..
Thank you!
Roy
Old Apr 24, 2008 | 08:46 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I would still bet you have another bad sensor. I don't think the engine is capable of actual oil pressure fluctuations as drastic as you are seeing; and if it pegs at all then I really suspect the OPS. Generally they do stay pegged, but yours might be partially broken or something... still trying to work but not quite cutting it. If your oil pressure was really 80psi (or 130psi per the DIC) I think you'd be seeing other problems.
Some people on here have had their sensors only last a week; one guy had his break only one day later. These new sensors are garbage.
I would change out the sensor again, especially if you're seeing absolutely nothing else amiss.
Old Apr 24, 2008 | 08:47 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Prolly just the sensor malfunctioning again, or a short in the wires going to it. I would bet it is the sensor though. I knew a guy that changed his and went 4 miles and it blew it again.
Old Apr 24, 2008 | 09:20 PM
zx-12r's Avatar
zx-12r
The sensor had already gone bad and pegged a month or more ago I had not replaced it yet but I have never seen it fluctuate like this. Could the oil pump or something be going bad????
Thanks,
Roy
Old Apr 24, 2008 | 09:23 PM
John S.'s Avatar
John S.
my oil pressure is pegged too. I plan on relocating the sensor per the sticky up top so I wont have to remove the manifold from here on out.
Old Apr 24, 2008 | 09:32 PM
zx-12r's Avatar
zx-12r
Mine is pegged but goes from pegged to 0 and back again.
Old Apr 24, 2008 | 09:35 PM
John S.'s Avatar
John S.
I would change the sensor again before looking further as these are notorious for going bad. I wouldn't worry until you get the same readings with a brand new sensor.
Old Apr 24, 2008 | 10:13 PM
Junkman2008's Avatar
Junkman2008
Hey Jason, allow me to slightly partake of your quote.
"I know you have another bad sensor. Your engine is not capable of actual oil pressure fluctuations as drastic as you are seeing without shaking itself out of the engine bay; and if it pegs at all then I know it's just another bad OPS. Generally they can go both ways, and yours is doing the same thing that so many others have done after being replaced. If your oil pressure was really 80psi (or 130psi per the DIC) it would blow the oil filter off the engine.
I would do the relocation mod so that WHEN the next one goes south, it's just a 10 minute fix.
Thank you Jason, we now return you to your regularly scheduled thread.
Old Apr 25, 2008 | 01:40 AM
DeeGee's Avatar
DeeGee
Anyone know why these sensors are so unreliable. Is it another cheap parts issue like the door relays?
Old Apr 25, 2008 | 04:35 AM
Junkman2008
I think it speaks volumes for where their made. I think most of the guys have ended up with OPS stamped with "made in Mexico".
Old Apr 25, 2008 | 12:47 PM
DeeGee's Avatar
DeeGee
Ahhh
Old Apr 25, 2008 | 06:54 PM
Alaskanpilot
BWAHAHA! Thanks for the improvements!
Old Apr 25, 2008 | 06:56 PM
Alaskanpilot
Agreed... the one I put in last week (GM replacement as well) was stamped "Made in Mexico". ANd... the one that came out was "Made in Mexico." So I believe my new one should last until roughly next Thursday at 3pm. I left my tools for this job out on the workbench.
Old Apr 25, 2008 | 09:48 PM
Junkman2008
Old Apr 25, 2008 | 10:14 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Quick way to tell if the sensor is bad is to turn the key to the run position without starting it. Then if the needle goes to the pegged side, it's the sensor. I did the relocation just a few weeks ago and am very happy I did for next time.
Old Apr 26, 2008 | 12:25 AM
zx-12r's Avatar
zx-12r
I know my sensor is bad but I have never heard of it bouncing from 80 to 0 and back to 80 again. Is there any way i may have a bad oil pump also?
Old Apr 26, 2008 | 12:43 AM
damilleniumboy's Avatar
damilleniumboy
I went through three different stinken OPS units last year, and they all came from GM, so this year it is stuck on 80 or 130 on my DIC . I have to change the sinken sensor again . Did I mention that one of them only lasted for a whole cruise around town after I got done installing the POS.
I just discovered why the call the Oil Presure Sending unit that. It is because it is a Piece Of $hit.
In conclusion the OPS=POS.
To NEED HELP !!! oil pressure
Old Apr 26, 2008 | 11:35 AM
mstromquist
Highly unlikely it's the pump. Mine did the same thing yours is doing. I replaced it and it works great. Like stated before, it's probably the sensor. That is where I would start.
Old Apr 26, 2008 | 07:15 PM
borkg2006's Avatar
borkg2006
A friend of mine had his go bad and got a super deal from NAPA. It lasted about 2 months and popped on him again. He called the NAPA store and they got him another one free. NAPA has pretty good prices on sensors for the C5's and they stand behind their products.
Old Apr 26, 2008 | 07:41 PM
robsc501's Avatar
robsc501
Default Need help!!! oil pressure
Hi There, zx-12r
I,am curious as to how many miles on your 01?
robsc501
