Swivel Fitting for Plug Wrench
Old Apr 28, 2008 | 02:21 AM
DeeGee's Avatar
DeeGee
Default Swivel Fitting for Plug Wrench
I'm about to change the plugs. Many of you have mentioned the swivel wrench to get out plug #7.
Do you need a 90 degree swivel or will a lesser swivel do the job. I have a plug wrench that gives about 45 degrees flex.
Old Apr 28, 2008 | 02:55 AM
RonVette2's Avatar
RonVette2
You can also buy a plug socket that has a double swivel, I bought one off the tool truck, ie: Snap-On, MAC, ect. they may have them at sears or something too. Great little tool, having the right tool(s) make the job(s) much easier,... and nice
Old Apr 28, 2008 | 03:50 AM
Junkman2008's Avatar
Junkman2008
Do you have any of those places over there DeeGee?
Old Apr 28, 2008 | 08:28 AM
robsc501's Avatar
robsc501
Default Swivel fitting for Plug Wrench
Hi DEE Gee,
Snap -on has a 5/8" 6 point double swivel socket p/n s9721 which is supposed to make removing #7 plug a breeze. I think its about $40. dollars. (good p/n its on their site plus a picture).Everyone swears by it.Only have 13k on the clock on my 01 coupe. so when the time comes I might buy it. A Mac tools driver gave me this p/n bduup206a(double swivel 5/8" 6 point) but the last time I was at their web site I could not find it, which means he gave me the wrong p/n.
I think you could use a standard universal along with disconnecting the AIR valve pipe connector located right in the way of #7 cyclinder.If your using the ac-delco plug 41-985 the gap must be .40 & not .60. Use anti- seize for the next plug change.Whats your opinion about disconnecting the AIR pipe & a regular universal? I would use the rubber hose trick to start the threading & removal of the plug as it looks very easy to drop a plug at installation.
Hope this helps you.
robsc501
ret. aircraft engine technician(piston type)
Old Apr 28, 2008 | 08:36 AM
rcs128's Avatar
rcs128
No, a 45 degree swivel will be fine. Just be sure you have a couple extensions to make the reach easy. I used 2 4-inch extensions and was fine. The job's not nearly as hard as some make it out to be. Just take your time and you'll be fine. I did all 8 plugs in about an hour, and I had never done an LS1 before.
The most challenging thing I ran into was getting the plug wires off -- those suckers were on there and it's tough to get a good grip on the boots. I was replacing wires at the same time, so I wasn't too worried about damaging them -- but if you're re-using the wires, be careful.
Rich
Old Apr 28, 2008 | 08:43 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I just pull the coil packs and valve cover off, it give quite a bit of room to get to the plugs on teh back.
Old Apr 28, 2008 | 08:45 AM
Vega$Vette's Avatar
Vega$Vette
Use a little dielectric grease on the plug wire boots when you put them back on. Keeps the moisture out and makes them come off a lot easier next time.
Old Apr 28, 2008 | 10:19 AM
stingray71's Avatar
stingray71
I just did this last week and didn't really need any special tools. I used a regular spark plug socket, a universal joint, and a couple of extensions (one 3" and one 9").
This was the toughest, but it wasn't as bad as I thought. My hands are thin enough to get the spark plug in by hand (just barely). I don't know how people with big or "wide" hands can do this plug. There's not much room even when you move the rubber hoses out of the way.
Old Apr 28, 2008 | 10:47 AM
robsc501's Avatar
robsc501
Hi Rich,
Thanks for the info.Now DEE Gee & I will not have to spend $40 for one socket.
I think I will put some silicone grease on the boots today to avoid busted knuckles in the future.I will be using the rubber hose as an extension to avoid dropping the plug when I change my plugs as I have big hands.
robsc501
Old Apr 28, 2008 | 11:15 AM
jrprich's Avatar
jrprich
This is what I bought, cheap, but they work and I only use them for this job
http://www.monstronix.com/kti22048-pr-52800.html
http://www.monstronix.com/sun3400-pr-60707.html
Old Apr 28, 2008 | 12:09 PM
robsc501's Avatar
robsc501
HI Jim,
Those two items look like the perfect tools for the job.
robsc501
Old Apr 28, 2008 | 12:28 PM
jrprich's Avatar
jrprich
Originally Posted by robsc501
HI Jim,
robsc501
Sure,
Like I said, these are cheap tools.........if I was buying for daily use I would buy high quality sockets, but for this single task they do fine.
And Free Shipping
Old Apr 28, 2008 | 12:35 PM
Junkman2008
I don't know...that Snap-On tool would look nice in my specialty collection. I could set it next to my shaft seal installer!
Old Apr 28, 2008 | 12:41 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The hardest one to take out I found was the one by the driver's side firewall. I used a regular spark plug socket a universal joint and 4" estension. went right in. Try it before you go out and buy anything. My .02
Old Apr 28, 2008 | 01:19 PM
jrprich's Avatar
jrprich
Must be nice to have a Speciality Collection
Old Apr 28, 2008 | 01:27 PM
dndrsn's Avatar
dndrsn
S•K double swivel spark-plug socket set. $25 shipped on Eplison-Beta/Alpha/Upsilon.
Old Apr 28, 2008 | 02:08 PM
Junkman2008
I prefer Echo-Beta/Alpha/Yankee.
To Swivel Fitting for Plug Wrench
Old Apr 28, 2008 | 02:13 PM
dndrsn's Avatar
dndrsn
Echo-Bravo/Alpha/Yankee
A Jar Head would say that.
Old Apr 28, 2008 | 02:15 PM
ericdwong's Avatar
ericdwong
Rich
Everything he said. This isn't like a Camaro, even with OEM manifolds I have no trouble changing the plugs at all.
Old Apr 28, 2008 | 02:16 PM
Junkman2008
