cleaning underhood pad
Old Apr 29, 2008 | 01:15 PM
2vetteguy's Avatar
2vetteguy
Default cleaning underhood pad
What is the best way to clean the underhood pad on my 2000 vert?I have vacumned it and it still doesn't look as clean as I would like, any suggestions appreciated
Old Apr 29, 2008 | 01:22 PM
Jakeross's Avatar
Jakeross
Last week there was a thread about painting the pad with high temp paint.
Old Apr 29, 2008 | 01:24 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
There was a post on this a few weeks back. Do a search and you will likely find it.
Old Apr 29, 2008 | 01:38 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Used my compressor on it to blow the dust out and painted it with flat black. Painted the emblem on it with Paint pens and sprayed it all over with clear satin. Now I just hit it with a little compressed air and the dust goes away.
Old Apr 29, 2008 | 03:19 PM
DeeGee's Avatar
DeeGee
Refurbishing a Corvette C5 Hood Liner
The liner is made of a very delicate material so be careful in how you handle it once it’s removed. The surface is a fabric type finish and hard brushing will cause it to become rough and fibrous. It will also crack easily if you let it flex so if you take it outside beware of strong wind.
As you take the final fasteners out, support the liner so you don’t crack the liner around the eyelets.
The actual work takes only minutes. The drying time is the only slow process.
As you can see, the liner will have attracted quite a bit of dirt and grime.
OK here we go.
Lift the hood.
Remove the fasteners gently, top, then bottom and middle ones last. This will support the liner better as you take them out. Us a tool with a forked end. I’ve heard of a barbeque fork being used. I used a nail puller work in behind the fastener.
Take the liner outside and brush the surface gently with a soft brush to remove any dirt. Take care not to damage the surface of the liner.
Spray the liner with black paint. The difference between the old and the new surface is immediately apparent.
Use as many coats as you see fit. The liner is porous so it will take at least 3 coats to get good coverage. Leave it for 30 mins between coats to allow the paint to dry.
If you plan to paint the Corvette emblem, you may wish to apply extra paint around the embossed area on the liner. This will stop the liner absorbing the coloured paint.
Once the paint is dry (and you may wish to leave it overnight), you can either paint the emblem or apply a decal. I chose the decal. Alternatively if you prefer, you can refit the liner and apply the decal when it’s back in place.
Refit the liner in the hood fitting the middle fasteners first to hold it in place, then refit the remaining fasteners. A gentle push fit is all it takes to reinsert the fastener.
The finished Hood Liner
Old Apr 29, 2008 | 03:24 PM
4 KRUSIN's Avatar
4 KRUSIN
I agree with Dee Gee. Follow his instructions and use black Barbeque paint. Its cheap, takes high heat and has a non-gloss finish.
Dave
Old Apr 29, 2008 | 03:40 PM
Benpup's Avatar
Benpup
Dave
Damn I just used flat black. Had three cans of BBQ paint just sitting there and didn't even think about them (slap in the head) I shoulda had a V8.
Old Apr 29, 2008 | 03:42 PM
Chicago1's Avatar
Chicago1
OK here we go.
Lift the hood.
Very nice write up where did you get the underhood sticker?
Old Apr 29, 2008 | 05:56 PM
GRUNIE's Avatar
GRUNIE
Nice "how to" DeeGee
Old Apr 29, 2008 | 06:04 PM
dobewillie's Avatar
dobewillie
great post DeeGee many thanks
Old Apr 29, 2008 | 09:27 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Silly, you HAVE a V-8!
Old Apr 29, 2008 | 09:34 PM
moserbe's Avatar
moserbe
Great pics DeeGee. Thanks.
Old Apr 29, 2008 | 11:54 PM
rrichar2591's Avatar
rrichar2591
Thanks for posting this "how to". Now I've got a future project! Where did you get the decal from? I like it a lot.
Old Apr 30, 2008 | 12:46 AM
DeeGee's Avatar
DeeGee
RPI Designs but Testors paint works just as well if you have the time and a steady hand
Old Apr 30, 2008 | 02:32 AM
98siLVERbULLET!'s Avatar
98siLVERbULLET!
I painted mine and it looks better than new. take your time and it comes out perfect.
Old Apr 30, 2008 | 11:02 AM
02gt350's Avatar
02gt350
spray paint it flat black. looks brand new
Old Apr 30, 2008 | 12:45 PM
bucwheat's Avatar
bucwheat
Looks great ,thanks for the tips.
To cleaning underhood pad
Old Apr 30, 2008 | 04:30 PM
waddisme's Avatar
waddisme
Don't forget your can go to Home depot and get the chrome drain covers to use instead of the oem plastic fastners. That is if you want a little more . Thanks for the write up.
Old Apr 30, 2008 | 06:00 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Good Article!
Old Apr 30, 2008 | 10:08 PM
Fast Cop's Avatar
Fast Cop
DeeGee, great post, thanks.
