Running light replacment
Old May 1, 2008 | 12:01 AM
dljenkins's Avatar
dljenkins
7th Gear
Default Running light replacment
I own a 2001 Corvette ZO6 and the right front running light/turn signal bulb is out (which means I lose my turn signal on the right side completely).
The owner's manual tells you how to replace the rear bulbs but only says "see dealer" for the front. How do I get to the bulbs under the headlights in the front so that I may replace the faulty bulb?
Thanks,
Derrell
Old May 1, 2008 | 12:43 AM
Junkman2008's Avatar
Junkman2008
Here you go Derrell. You will need to download this zip file and extract these 3 PDF files. This is the proper way from the manual.
Old May 1, 2008 | 01:01 AM
dljenkins's Avatar
dljenkins
7th Gear
Thank you, I will give it a try.
Derrell
Old May 1, 2008 | 01:25 AM
DeeGee's Avatar
DeeGee
I didnt look at Junkmans link but he knows his stuff on the lighting
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Old May 1, 2008 | 01:47 AM
Junkman2008
Popeye just has Olive Oil change his.
To Running light replacment
