oil change question
Old May 2, 2008 | 11:20 AM
njvette98's Avatar
njvette98
Default oil change question
what type of oil does everyone use on their c5 i see alot of people use the 5w 30 mobil synthetic also how many quarts does it take tired of paying somebody to change my oil on this vehicle only since its low to the ground
Old May 2, 2008 | 11:38 AM
jrprich's Avatar
jrprich
Do a search on Oil Change and you will find many step by step posts on how to do the change
Old May 2, 2008 | 11:44 AM
GR8-LIFE's Avatar
GR8-LIFE
The past year I have been trying to do my own work on my car because I too am tired of letting others work on it. With me its nothing to do with money or lack of confidece in others, but rather eliminating my own laziness to learn to do it myself. But I've had enough of my periodic laziness. I have had lift for 18 monts now and I didnt get it just to change out the wheels for the track or inspect rotors or oil lines around my turbos
Anyway, I just did mine the other day and i put in 6 quarts. But it actually takes 6.5 quarts or something like that. Unless you tip the car foward, you wont get all the oil out. Personaly, I dont worry about the remaining 1/2 quart. Some jack up their cars in the rear a little higher to get everyhting out. But ya gotta be carefull the car doesnt slide on the jacks
I use the heavy weight 15-50 only because the turbos require the thicker oil. Most guys who run their cars on roadcousres use the thicker oil because it it keeps oil pressure higher. So even if I didnt have the turbos, I would stil use the heavier weight. That just me. Oh ya. Mobil-1 Pure synthetic all the way
Old May 2, 2008 | 12:27 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There are a number of full synthetics on the market that meet GM4718M - which is the standard for the LSx engines.
The manual recommends 5W-30 in all applications, with 10W-30 as an alternative.
The stated capacity for the LS1 is 6.5 quarts, but I use slightly more than that to get it up to the full mark on the dip stick.
Old May 2, 2008 | 12:30 PM
itzza427's Avatar
itzza427
5W30 is the factory fill,,They tested the oil life monitor system with this oil on cars in excess of 200k mi. There are vets out there with 100 and 200k still running out there. It's even good for moderate racing!!
Old May 2, 2008 | 01:05 PM
steve8's Avatar
steve8
5-30, and 6.5 qts here.
Old May 2, 2008 | 01:11 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Old May 2, 2008 | 01:19 PM
VinnyT's Avatar
VinnyT
I use Warren 10w/40 from a convenience store.
j/k
Mobil 1, 6.5 quarts. I also bought a 15mm ratchet wrench.
Old May 2, 2008 | 02:02 PM
Tom/99's Avatar
Tom/99
Mobil 1, 10W-30, 6 1/2 quarts, and a Delco PF46 filter.
Old May 2, 2008 | 02:21 PM
moserbe's Avatar
moserbe
You can also use a PF44 oil filter.
Old May 2, 2008 | 06:39 PM
rws.1's Avatar
rws.1
5 W 30 weight of an oil meeting GM4718M
Formula Shell Fully synthetic
Quaker HorsePower
Pennzoil Platinum
Mobil 1
Castrol Syntec
Royal Purple
Ammsoil
RedLine
all meet that spec....
Old May 2, 2008 | 07:31 PM
tellefan's Avatar
tellefan
Mobil 1, 5-30 and Mobil I oil filter. There is tons of info on the subject if you do a search. Most folks agree that if you have a STOCK engine 5-30 is the way to go because of such tight tolerances built into the engine.
The oil question will start a wildfire of posts from folks swearing that their way is the best. If GM designed the engine, tested it and recommended Mobil 1, 5-30 then that's what I'll run. Flame suit on. David
Old May 2, 2008 | 08:14 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default oi
Hi, your logic is absolutely sound. However, every drop of lubricant in my car is Amsoil. Reason? First synthetic (since 1976?)
developed, and I hope that they are ahead on the development curve. Perhaps it's foolish, but I'm pleased with it, and the company's fabled self promotion makes me feel secure in using it. I'm sure it's as good as Mobil.
Regards, GRT
Old May 2, 2008 | 08:22 PM
tellefan's Avatar
tellefan
developed, and I hope that they are ahead on the development curve. Perhaps it's foolish, but I'm pleased with it. I'm sure it's as good as Mobil.
Regards, GRT
I've been thinking about Amsoil, it's the ONLY other oil I would consider using. It just happens, Costco had a great deal on Mobil 1, so I stocked up. David
Old May 2, 2008 | 09:00 PM
jrose7004's Avatar
jrose7004
1st, get a owners manual!
Old May 3, 2008 | 12:03 AM
I use Mobil 1 5W30 - 6.5 quarts.
Old May 3, 2008 | 12:05 AM
mvarga's Avatar
mvarga
Mobil one 5-30. It took a little less than 7 quarts.
To oil change question
Old May 3, 2008 | 01:43 AM
2KFRC5's Avatar
2KFRC5
Here's the current list:
GM - Registered Oils meeting GM4718M & GM6094M
Old May 3, 2008 | 04:39 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Takes me about 12 minutes to get it in the air if I hurry and way worth it to change the oil myself. If you have a place to do it, don't let anybody else touch your car......when you do it, you know it's done right!!
Old May 3, 2008 | 05:26 AM
damilleniumboy's Avatar
damilleniumboy
Originally Posted by 2KFRC5
That is a cool list.
