The oil question will start a wildfire of posts from folks swearing that their way is the best.
I'm actually surprised it has lasted this long.
If GM built an engine that was so unforgiving as to which synthetic oil was used, then we (and GM) would all be in big trouble.
With that said, track condiions will require different oil, atleast if you want to be able to run longer. Run a bone stock car MN6 for 30 minutes with 5w30 and observe the oil pressure and temps. Log the numbers
Then the next time on the track, put in a thicker oil and run 30 minutes and see what the pressure and temps are. Its a big difference and I saw this when my car was bone stock.
But For daily driving on a bone stock car, it really doesnt matter
I didn't realize Amsoil is not on the list. So..... I'll stick with Mobil 1. David
Keep in mind that your owner's manual doesn't require an oil do be on this list, nor does it even mention anything about "registered" oils. I suspect, but don't know, that this list is an advertising revenue generator for GM. Your owner's manual requires an oil meeting GM Standard 4718M. Many synthetic oils on the market meet this standard, including several from AMSOIL.
For the original poster, the C5 LS1 motor should take about 6.5 quarts of a 5w30 meeting GM Standard 4718M. 10w30 is allowed as an alternative above 0F. 0w30 is not mentioned, but many, including myself (in my 06 CTS-V daily driver), use it as it will flow better when cold and help reduce wear while the oil is warming up.
As mentioned by Mark above, most guys that track the car use an oil with higher viscosity. I use a 10w40 in my C5 Z06 which sees exclusive track use these days.
what type of oil does everyone use on their c5 i see alot of people use the 5w 30 mobil synthetic also how many quarts does it take tired of paying somebody to change my oil on this vehicle only since its low to the ground
Just changed the oil in Mrs. Parches' C5 today. Put in Amsoil Signature Series and a PF46 filter. Been using Amsoil for more than 20 years with excellent results. I use Amsoil tranny and gear oil in both my C5's as well and I switched my Hummer over on the first oil change recently.
