Seat replacement help...
Old May 2, 2008 | 10:10 PM
vetterman1980's Avatar
vetterman1980
Default Seat replacement help...
Hi. i just purchased a 2000 C5 i wanted to know if the driver and passenger seat foam were interchangable or not? The drivers seat bottom is hard and uncomfortable and i would rather pass that burden onto the passenger. Any help or pictures on how to do it is greatly appreciated thanks.
Old May 2, 2008 | 10:15 PM
fireman591's Avatar
fireman591
Not sure if they are interchangable but this link shows how it is done.
http://www.vetteessentials.com/instr...er_change.html
Good luck
Fireman591
Old May 2, 2008 | 10:17 PM
71vetteinva's Avatar
71vetteinva
How bad is it? My cushion was worn and the leather was cracking, so installed Wet Okole seat covers. They look great and there is about a half inch of padding sewn into them. The seats in my 2000 have never felt so comfortable.
Old May 2, 2008 | 10:21 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
The foam is the same. but you do have to cut some of the foam for the trim pieces to fit.
Old May 3, 2008 | 12:32 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i swapped my driver & passenger side foam when i changed my seat covers a couple months ago.
i did have to do some trimming for the controls and the bezel screw holes but it still worked out fine.
the passenger foam was like new.
Old May 3, 2008 | 01:15 AM
Jet-Jock's Avatar
Jet-Jock
Leave the pax seat alone, just order a single seat cushion set or even better if your back is ok just the bottom. Its not that expensive and your only tearing apart one seat.
Seat Foams C5
They should be inter-changable.
Old May 3, 2008 | 01:25 AM
DeeGee's Avatar
DeeGee
I haven't changed the foam but I've stripped the seats down. Its a reasonably long job. For $90 for a replacement seat base - and you'd get a better discount from the forum dealers - I'd buy a new one and save further hassle.
Old May 3, 2008 | 08:57 AM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Default Getting mine replaced
There is a difference in price between the two seat foam bottoms, as well as for the holes mentioned above for the trim pieces to fit. I don't know why there is a difference in the price; maybe it's thicker or reinforced in some way. I would think the passenger seat foam would be in better condition than the drivers seat. Why do you want to replace the passenger seat foam?
Old May 3, 2008 | 06:16 PM
vetterman1980
i dont i want to replace the drivers side, anyone know of a good price on a new ds foam i only need the bottom
Old May 3, 2008 | 09:12 PM
jdmvette's Avatar
jdmvette
Night Owl for life
gmpartshouse.com
||--Genuine GM Sport Seat Foams/Pads--||
97/98/99/00
10273418 – D/S & P/S seat back outer foam – 28.36 each
10283891 – D/S & P/S seat back insert foam – 57.31 each
10273420 – D/S & P/S seat cushion foam – 73.94 each
To Seat replacement help...
