Trunk window hold down-Oil sensor
Old May 2, 2008 | 02:59 PM
Stroke03's Avatar
Stroke03
Default Trunk window hold down-Oil sensor
I had the tapered rubber plug missing on the end of the spring loaded
latch that holds the extra window in place in the trunk. I went to the
stealer and they did not sell the rubber bumpers, you had to buy the whole latch assembly at approx. $50.00 each. So I went to the hardware
store an purchased rubber tapered plugs. Get the ones that are 1/2" at the big end. Drill a 1/4" hole down the center of the rubber plug. Place the drilled plug on a short 1/4" wooden dowel and place in you power drill.
I rotated mine in reverse against my power sander to sand down from 1/2"
to 1/4" taper. Works great and you cannot tell it from original. No more
rattles in trunk. Plugs cost .40 cents each, get extras just in case you
screw up. I am handicapped from a stroke and I replaced my oil sender by
cutting the small access hole in the bottom of windshield drain pan and it
took me one hour start to finish. If I can do it you can do it. Good luck !
Old May 2, 2008 | 04:58 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
I'm having a "why didn't I think of that!" moment
Great idea. I need to get mine replaced, so I guess it's off to the hardware store.
Old May 2, 2008 | 05:13 PM
Junkman2008's Avatar
Junkman2008
Pictures are worth a thousand words!
Old May 2, 2008 | 09:43 PM
dobewillie's Avatar
dobewillie
great fix
Old May 2, 2008 | 10:04 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Is the sensor directly below the tray?
Old May 2, 2008 | 11:32 PM
Way to be creative and beat the Corvette tax.
Old May 3, 2008 | 01:58 AM
DeeGee's Avatar
DeeGee
Those things are useful
I made this up after a trip to Home depot
Great idea BTW
Old May 3, 2008 | 09:49 PM
Stroke03's Avatar
Stroke03
I am new to forum and do not know how to get my jpeg
pictures included. Pictures on how to do the oil sensor are already on the
forum. Just search "oil sensor".
Old May 3, 2008 | 11:31 PM
Junkman2008
Here you go. Now you have the power!
How to Post Pictures:
http://forums.corvetteforum.com/show....php?t=1336867
Old May 3, 2008 | 11:48 PM
WvCorvette's Avatar
WvCorvette
Old May 4, 2008 | 12:06 AM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Nice fix. Corvette Central has the replacement tips if anyone is as lazy as I am. That's where I got mine.
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old May 4, 2008 | 07:14 AM
vetter79's Avatar
vetter79
99Mallett - You sent a bad link -Please repost!
Old May 4, 2008 | 12:03 PM
RJ1AZ's Avatar
RJ1AZ
It cost me .89 cents apiece for some rubber stoppers at my local hardware store, and about 10-15 minutes with my drill and palm sander to get them shaped right.
http://corvettecentral.com/
Their part number is 605030. They want $8.95/pair plus whatever shipping comes to
C'mon, it's two pieces of rubber! Hello Corvette Tax.
Old May 4, 2008 | 11:43 PM
Stroke03's Avatar
Stroke03
It is towards the drivers side, left of center. Remove the
drivers side fuel rail cover and locate sensor using a flashlight. Mark location of center of cut, then cut a 4x4 access hole.
To Trunk window hold down-Oil sensor
